3" exhaust and 22mm sway bar
Old Oct 30, 2001 | 09:40 AM
porch's Avatar
New User
Default 3" exhaust and 22mm sway bar
Does anyone have both? Do you have any clearance problems? I currently have a 2.5" exhaust and if/when I go turbo I will prolly upgrade to a 3". My 2.5" will bounce (very lightly) off the sway bar from a stop, because the rubber hanger will stretch just enough from starting. There's really not much more room under there as it is, so I was wondering if anyone has done this and how much clearance problems they have.
Old Oct 30, 2001 | 09:56 AM
TurboSedan's Avatar
New User
Default Re: 3" exhaust and 22mm sway bar (porch)
From what I understand, there probably will be clearance issues unless you bend the exhaust hanger so that the pipe sits up higher from the sway bar.
Old Oct 30, 2001 | 10:00 AM
HX_Guy's Avatar
My 2.5" exhaust "bounced" on my rear 19mm sway bar once in a while...I fastened a rubber piece between the exhaust and the sway bar and no more noises
Old Oct 30, 2001 | 10:27 AM
LEON's Avatar
I have had not problems... I'm running a 3" Thermal exhaust with a 22mm Type R swaybar.
Old Oct 30, 2001 | 12:05 PM
acuraintegraman's Avatar
Default Re: 3" exhaust and 22mm sway bar (LEON)
i'm running a 3" thermal and itr sway bar, no problems
Old Oct 30, 2001 | 03:31 PM
954DR's Avatar
New User
Thermal 3' & Comptech 22 - no probs.
Old Oct 30, 2001 | 03:32 PM
liam821's Avatar
25 Year Member
Default Re: 3" exhaust and 22mm sway bar (954DR)
Even if you did have a problem...nothing a muffler shop cant fix.
liam
Old Oct 30, 2001 | 06:16 PM
TurboITR's Avatar
Default Re: 3" exhaust and 22mm sway bar (liam821)
i got a 26mm - thermal 3in fits fine...
justinwinn
Nov 25, 2010 04:31 PM
Maireeka
Suspension & Brakes
Nov 12, 2007 03:17 PM
94maroonturbocp
Oct 29, 2004 08:31 PM
hondacivic4g
Dec 17, 2003 09:28 PM
