please help. right turn signal wont turn off
Old Apr 19, 2004 | 12:35 PM
mv10s's Avatar
Default please help. right turn signal wont turn off
92 accord ex, right turn signal won't turn off. i have disconnected the front right and rear right turn signal bulbs to see if it's grounded improperly. still the dash/instrument cluster keeps flashing the right turn signal. when i push the emergency light it overrides flashing right turn signal. what i ended up doing is I disconnected the fuse powering the signals. unfortunately, now i don't have turn signals. everthing else works fine including the emergency flasher. It may be inside the steering wheel because the signal lever doesn't stay locked for right turn but does for left turns. any help and suggestions is appreciated. thanks.
Old Apr 19, 2004 | 08:43 PM
kittedaccord's Avatar
Default Re: please help. right turn signal wont turn off (mv10s)
it could be a switchin the sterring wheel column, or a short some where. better use the hand signals!
Old Apr 19, 2004 | 09:57 PM
The_Todd's Avatar
Farts in the shower
Default Re: please help. right turn signal wont turn off (kittedaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kittedaccord &raquo;</TD></TR><TR><TD CLASS="quote">it could be a switchin the sterring wheel column, </TD></TR></TABLE>
If you need a part for kinda cheap either check the accords being parted out in this forum or check http://www.hondaautomotiveparts.com very fast shipping and great prices for OEM honda
mr.bronx75
Lighting
Jan 27, 2008 08:50 AM
excivicboy96
10
Mar 21, 2007 02:48 PM
BoyRacer007
Feb 15, 2005 11:20 PM
