D-series VTEC vs. nonVTEC dizzy, what's the difference?
Old Apr 19, 2004 | 12:23 PM
zanthrax's Avatar
Default D-series VTEC vs. nonVTEC dizzy, what's the difference?
What is the difference between a D15B7 distributor and the one on a D16Z6?
Any pics maybe?
And are they interchangable?
I did a search but found 0 pics and not exactly the answer I was looking for.
Old Apr 19, 2004 | 12:28 PM
yonnage's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (zanthrax)
VTEC will not engage with the D15B one, unless you modify it (should fit directly on the Z6 head).
Probably much easier and more reliable to get the D16Z6!
Old Apr 19, 2004 | 12:51 PM
kadburry's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (yonnage)
the holes are different between the two
Ignitecivic's Avatar
the difference between these two is that one is call vtec and the other is non-vtec.
the d15b7 will fit on the d16y8 sohc vtec head though.
Old Apr 19, 2004 | 12:59 PM
kadburry's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (Ignitecivic)
heres the z6:
heres the b7:
Old Apr 19, 2004 | 01:04 PM
zanthrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yonnage &raquo;</TD></TR><TR><TD CLASS="quote">VTEC will not engage with the D15B one, unless you modify it (should fit directly on the Z6 head).
Probably much easier and more reliable to get the D16Z6!</TD></TR></TABLE>
You read my mind! I bought a Z6 head with no dizzy, and the one on my B7 is 6 months old.
So it should bolt right on but leave me without VTEC?
Could you explain why VTEC would not engage with the wrong distributor in use?
Old Apr 19, 2004 | 01:09 PM
yonnage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax &raquo;</TD></TR><TR><TD CLASS="quote">You read my mind! I bought a Z6 head with no dizzy, and the one on my B7 is 6 months old.
Could you explain why VTEC would not engage with the wrong distributor in use?</TD></TR></TABLE>
It's not wired to handle VTEC (The B7 doesn't have VTEC - Right?). I do not exactly know what you need to do to make the B7 distributor work, but as I said.. you are probably better off going with the Z6 distributor.
You should be able to find one at a junk yard or ebay for under $100. Otherwise, try searching to find out how to modify your existing one, and to see if it would work.
Old Apr 19, 2004 | 01:40 PM
TorganFM.'s Avatar
****.... I didn't know the distributor had wires for vtec. I thought the vtec wires went straight to the ecu. Could Bauley or someone else please set this thread straight?
Old Apr 19, 2004 | 01:41 PM
a1320honda's Avatar
ok, the dist. has absoulutly nothing to do with vtec. the b7 will physicaly mount to the head. but only one hole will partialy line up. it all plugs in electrical wise. but you have to cut and grind the end of the posts for it to fit and use big washers. it will work, but looks ghetto as hell. the #'s on the dist. are....b7 is td-41u, the z6 and z1 (vx) are td-42u. the ex,si,and vx will all work the same as well as working on a jdm d15b vtec. hope that helps
Old Apr 19, 2004 | 02:07 PM
Katman's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (kadburry)
nice dizzy pics .. got any more?
Old Apr 19, 2004 | 02:09 PM
kadburry's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (Katman)
i took them off ebay
Old Apr 19, 2004 | 02:26 PM
bloopie's Avatar
There isnt such thing as a VTEC dizzy. They are just different because they mount a little different. Once again, please stop spreading mis-information.
This is the second "VTEC Dizzy" post Ive seen this week.
Old Apr 19, 2004 | 10:36 PM
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (veReze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veReze &raquo;</TD></TR><TR><TD CLASS="quote">There isnt such thing as a VTEC dizzy. They are just different because they mount a little different. Once again, please stop spreading mis-information.
This is the second "VTEC Dizzy" post Ive seen this week.</TD></TR></TABLE>
he is correct. there is no such thing as vtec dizzy. the harness on the b7 and z6 dizzy are identical, just that the bolt part are different. it dont do anything with vtec kiking in.
Old Apr 19, 2004 | 10:43 PM
SOHC_MShue's Avatar
yup the z6 dizzy hole pattern is different than the b7. In fact i think its different than all the other d series dizzy patterns correct? I put a built z6 head on a y8 block in a 97 civic ex before and ended up having to modify the y8 dizzy to fit. It was only being held on by one bolt
Old Apr 20, 2004 | 01:38 PM
BauleyCivic's Avatar
Risky Business
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (SOHC_MShue)
They are not interchangable. Z6 distributor will not fit with anything.
This is what I do know:
Y7 dizzy will fit on Y8 and vice versa
A6 dizzy will fit on Y7/Y8 and vice versa
B7 dizzy will fit on A6 head and vice versa (pretty sure)
Old Apr 20, 2004 | 02:40 PM
Katman's Avatar
just some helpful info..
I recently installed a Z6 dizzy onto a 92-95 D15/DX engine, and of course it didn't bolt right up. I had to modify the top mounting hole to make it work on the DX engine.
I'm not sure what other people use to widen the mounting holes on a dizzy when it comes to situations like this, but I found the PERFECT dremel bit that gets the job done real quick.
its this bit:
http://www.dremel.com/productd...09999
It cuts through aluminum like a hot knife thru butta.
enjoy ya' self.
Old Apr 20, 2004 | 03:20 PM
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">They are not interchangable. Z6 distributor will not fit with anything.
the b7 and b8 dizzy will fit the y8 as well. i tried it myself when i purchase the y8 head.
Old May 1, 2004 | 01:55 PM
hondaguyexsi's Avatar
d series dizzys are interchangable
Old May 2, 2004 | 02:18 PM
bloopie's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (hondaguyexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyexsi &raquo;</TD></TR><TR><TD CLASS="quote">d series dizzys are interchangable
Not all of them. People will read this and think that their DUAL POINT 88-91 dizzy will work on an EG if they aren't that knowledgeable. Just a heads up.
Old May 2, 2004 | 02:23 PM
ABK's Avatar
ABK
No that dizzy won't bolt up without modifications. I think it would work but I'm not totaly sure, when I was doing the swap on my friends car we decided to just play it safe and get z6 dizzy for $100 from the same shop we got the motor from.
But I'm pretty sure you can make some custom **** to make it hold on the head better.
If you are going to do it hit us back.
Old May 2, 2004 | 05:07 PM
Br1anPham's Avatar
Default Re: D-series VTEC vs. nonVTEC dizzy, what's the difference? (ABK)
A d15b7 dizzy will work with a d16z6 head. you need to line up the top hole to the head then slot another hole and put a big washer and the botl through it to hold it down in place. You will have a shitty range of timing adjustability but it will work. Has nothing to do with vtec, vtec will still work.
Old May 2, 2004 | 05:13 PM
chad's Avatar
Moderator
haha...nice informative post.....
i had a d15b dizzy mounted and running on my mini me setup....with non vtec spark plug wires.....
the DIZZY has NOTHING TO DO WITH VTEC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
period.......
yes you must modify the dizzy and wires to make them work!1
biggishjay
11
May 29, 2007 08:45 PM
littoboypinoy
16
Oct 26, 2006 04:19 PM
highriskZc
May 13, 2006 08:51 PM
lilneep16v
Feb 28, 2005 05:26 PM
