Rear Sway Bar Options - Whiteline?
Old Apr 19, 2004 | 09:44 AM
typer_801's Avatar
Default Rear Sway Bar Options - Whiteline?
I'm trying to determine my options for a rear bar and don't feel like dropping the standard $400 for a Mugen 26mm.
I just came across a new option potentially. Whiteline lists an adjustable rear sway bar for the ITR (24mm) which appears to adjust to a corresponding range of 22-26mm.
Part # (code): #BHR72Z
Price: ~$165 USD
Anyone ever used this bar? How in the heck do you order one here in the states?!?
Old Apr 19, 2004 | 09:48 AM
.RJ's Avatar
.RJ
Default Re: Rear Sway Bar Options - Whiteline? (typer_801)
I'm going to order one..... eventually.
Maybe for next year.
Old Apr 19, 2004 | 10:07 AM
EkREV's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to determine my options for a rear bar and don't feel like dropping the standard $400 for a Mugen 26mm.
Price: ~$165 USD
Anyone ever used this bar? How in the heck do you order one here in the states?!?</TD></TR></TABLE>
i've ordered a couple of these swaybars for a wrx...i'd have to check if i'm able to pick one up for a DC2...
Old Apr 19, 2004 | 10:15 AM
AdamITR's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (EkREV)
FYI, we carry Whiteline sway bars. I'm checking on pricing for the one stated above.
Adam
http://www.curpiermotorsport.com
Old Apr 19, 2004 | 10:27 AM
typer_801's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (AdamITR)
This is great, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamITR &raquo;</TD></TR><TR><TD CLASS="quote">FYI, we carry Whiteline sway bars. I'm checking on pricing for the one stated above.
Adam
http://www.curpiermotorsport.com</TD></TR></TABLE>
Old Apr 19, 2004 | 12:13 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamITR &raquo;</TD></TR><TR><TD CLASS="quote">FYI, we carry Whiteline sway bars. I'm checking on pricing for the one stated above.</TD></TR></TABLE>
Whoa, nice!
I might need one for trackside delivery later this year
Old Apr 19, 2004 | 12:29 PM
98itR484's Avatar
Adam
If i can get one before May 20, ill gladely buy one from you and give it a try
Arno
Old Apr 19, 2004 | 12:31 PM
AdamITR's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (.RJ)
I will have a price the A.M.
I'll reply to this post.
Old Apr 19, 2004 | 12:44 PM
Chris N's Avatar
I'd be interested to hear some thoughts on this bar from those that have had it for a while....
Chris - who would gladly sell his mugen 26mm for a good adjustable bar.
Old Apr 19, 2004 | 12:48 PM
Holding monSteR's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (Chris N)
If anyone in Canada is interested in these i can get them cheaper than anyone else in the country.
Old Apr 19, 2004 | 02:27 PM
Timmy!'s Avatar
I think team-integra.net did a comparison on these to the type r. I think the way was mounted did seem to ideal to these guys. Cant remember Ill look for it.
Old Apr 23, 2004 | 12:03 PM
hungsteR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamITR &raquo;</TD></TR><TR><TD CLASS="quote"> I will have a price the A.M.
I'll reply to this post.</TD></TR></TABLE>
Any updates?
Old May 17, 2004 | 09:42 AM
typer_801's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (hungsteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR &raquo;</TD></TR><TR><TD CLASS="quote">Any updates?</TD></TR></TABLE>
I bought the last one Global Parts Source had. They're the authorized North American distributor. They had 2 in their warehouse about a week ago, someone else bought one and I got the other one. Shipped to my house Friday, installed Saturday.
Visually, the shape is identical to the OEM ITR rear bar, sans the ends of the bar. This bar is adjustable and has different end links supplied which allow you to choose from 2 positions. The holes are 1inch apart. The factory ITR link splits the difference of the two holes, meaning the first is inboard 1/2" from the OEM location and the the second is 1/2" further out. Color is metallic grey vs black and the diameter is 24mm vs 22mm. Bar is shipped with new end links and sway bar bushings (24mm yellow poly).
Install was easy, although the "Whiteline" graphic is upside down so unless you're a fly, you'll never be able to see it because it's facing the underside of the car
Haven't got the car off the jackstands yet, but I'm expecting a nice improvement in rear stiffness. In the meantime, maybe some of the mathematicians on the list can calculate the difference in stiffness between this bar (in both settings) vs. the OEM bar and the Mugen 26mm.
Old Oct 27, 2004 | 08:34 AM
mstewar's Avatar
i'm bumping this up from the archive as i am curious about the adjustability options with this bar. i notice that it has two settings.. what bar thickness do these settings correspond to? 24mm and 26mm? anyone have anything more to say regarding fitament?
Old Oct 27, 2004 | 09:12 AM
Black R's Avatar
25 Year Member
from the description, it sounds like the bar is thicker than stock, but the mounting points make it go anywhere between 22 to 24 to 26 effectively?
And whatever happened with the "saner" bar?
Also, didn't someone else have a 30mm hollow bar that was about as stiff as the mugen 26mm?
Hrmness..... I just don't know what to get.....
Old Oct 27, 2004 | 02:09 PM
db8sirg's Avatar
looks interesting. anyone else try them out yet?
btw price on global is $187.00 for the sway kit.
Old Oct 27, 2004 | 03:10 PM
JeffS's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
And whatever happened with the "saner" bar?</TD></TR></TABLE>
Saner desperately needs to work on their website. They've offered a civic/integra bar forever now and it's still not listed - and not a single picture to be found. The add in GRM is good, but directing them to that site is a horrible.
Old Oct 27, 2004 | 04:12 PM
StudioJDM's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (JeffS)
I can get these bars also..located in NC
Old Oct 27, 2004 | 06:43 PM
Kengs's Avatar
FWIW, I believe Cusco has a 25mm bar for a lot less than the Mugen 26mm.
Old Oct 27, 2004 | 06:55 PM
Willard's Avatar
Default Re: Rear Sway Bar Options - Whiteline? (StudioJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StudioJDM &raquo;</TD></TR><TR><TD CLASS="quote">I can get these bars also..located in NC</TD></TR></TABLE>
Location in NC?
Price?
Availability?
Old Oct 27, 2004 | 07:34 PM
.RJ's Avatar
.RJ
Default Re: Rear Sway Bar Options - Whiteline? (Willard)
The saner bars are available, whatever size j00 want.
I recently picked up a a 1" (26mm) ground-control bar used
Old Oct 28, 2004 | 06:32 AM
StudioJDM's Avatar
Im located close to Charlotte. Let me find out some definite pricing and I will let you know. Thanks
Old Oct 28, 2004 | 06:41 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The saner bars are available, whatever size j00 want.
I recently picked up a a 1" (26mm) ground-control bar used</TD></TR></TABLE>
.....technically, isn't 1" a 25.4mm bar?
Old Oct 28, 2004 | 09:56 AM
StudioJDM's Avatar
I can get them to you for 175 + shipping or if you are local, you are welcome to pick up. Local will have to pay sales tax though. I might be able to get them a little cheaper if I am doing more than one.
Old Oct 28, 2004 | 10:22 AM
hypa's Avatar
I should post a pic of my whiteline coils that rusted to **** in the span of a year. They have had serious problems in the past with bad coatings on their parts, and I know the Subaru community has somewhat shunned whiteline products.
just an fyi.....
