DIY Door Siding Question
Old Apr 18, 2004 | 10:43 PM
B16X's Avatar
Default DIY Door Siding Question
Any DIY pages with pics regarding removals of EK door sidings (interior)? I might break some locks.. thanks!
Old Apr 18, 2004 | 10:44 PM
Luserkid's Avatar
Default Re: DIY Door Siding Question (PADEK454)
Door siding? Do you mean door skin? or what do you mean? moldings?
Old Apr 18, 2004 | 10:45 PM
skip.two's Avatar
your door sidings? you put interior, so are you talking about your door panels?
answer and ask clearly. use your 5 posts wisely n00b.
Old Apr 18, 2004 | 10:47 PM
lone's Avatar
if you mean the door panels there is a screw in the change holder part and the thing around the door handle. take the cover off the door handle and use gentle force to pull the panel off.
Old Apr 18, 2004 | 10:55 PM
B16X's Avatar
Default Re:
If you read the post, there was "(interior)" written somewhere.. maybe you missed that.
lone, thanks man!
Old Apr 18, 2004 | 10:58 PM
skip.two's Avatar
Default Re: Re: (PADEK454)
maybe if you knew what it is called, then you would have gotten your answer faster. use better grammar and learn to search. its the ways of H-T. read the "RULES" post (2nd post) in this forum while your at it. its for all the n00bs on H-T.
Old Apr 18, 2004 | 11:28 PM
B16X's Avatar
Default Re: Re: (jL iLLuZiOnz 9)
It's called door sidings here.. not my fault. If you don't have an answer, then don't answer. N00bs? Learn how to type right.
Old Apr 18, 2004 | 11:34 PM
skip.two's Avatar
too bad the term is "door panel." n00b is the way we spell it. too bad you used your 5 posts already. would have known that if you learned how to read .
Old Apr 19, 2004 | 05:23 AM
illicon2003
Guest
Posts: n/a
there's a gas pedal and a brake pedal, and possibly a clutch pedal, drive your car to a shop if you don't know how to look at it and determine how it comes off.
braass91
Jan 4, 2008 09:08 AM
Solo2Vtec
Honda Civic (2006 - 2015)
Jan 30, 2007 10:56 PM
confusatron
Mar 20, 2006 09:41 PM
rsx03
Oct 13, 2002 10:19 AM
