All motor Sohc build up
ok here is my SOHC All MTR set up:
d15b7 block bored 20 over with p29 20 over pistons
knife edged crank, balanced and blue printed
d16z6 head with p&p
Zex stage 2 cam with skunk2 cam gear
skunk2 valve springs, retainers, high compression valves
P&P intake manifold
Ported throttlebody to H22 butterfly specs
Full MSD ignition
shimmed VTEC
DC 2 piece ceramic 4-2-1 header
custom 5inch intake
ACT stage 1 clutch with 11.5lbs flywheel
ZC/Si/Dx/ Tranny with Lsd unit
Yield 12.26.1 compressions runnin on 114 octane
The motor is not tuned yet and is being broken in before a dyno session takes place. Positive comments welcome
d16z6 head with p&p
P&P intake manifold
Full MSD ignition
shimmed VTEC
custom 5inch intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridhatch18 »</TD></TR><TR><TD CLASS="quote">ok here is my SOHC All MTR set up:
how'd u come up with that c/r number? i thought that the d15's piston pin location would have placed the p29's much lower in the block thus resulting in a lower c/r?
</TD></TR></TABLE>how'd u come up with that c/r number? i thought that the d15's piston pin location would have placed the p29's much lower in the block thus resulting in a lower c/r?
If you did not use VX 1.5 vtec-e rods in that d15b7 with the d16 pistons, then it was basically a waste of time, due to rod length/piston pin location. The d16 pistons will sit lower in the hole if they are 1.5 non vtec rods in a 1.5 block. Might wanna look into that. If you used some online compression calc like c speed or the sohc calc, they wont take this rod length difference into account and your numbers are false.
Liam821 (usually in the turbo forum) and his buddies had a project d15 drag car going. He ran into this problem. This is how i know of this first hand. Same set up as you with the vtec head. It mathematically makes sense also.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 »</TD></TR><TR><TD CLASS="quote">If you did not use VX 1.5 vtec-e rods in that d15b7 with the d16 pistons, then it was basically a waste of time, due to rod length/piston pin location. The d16 pistons will sit lower in the hole if they are 1.5 non vtec rods in a 1.5 block. Might wanna look into that. If you used some online compression calc like c speed or the sohc calc, they wont take this rod length difference into account and your numbers are false.
Good luck.</TD></TR></TABLE>
yea, it's around 10:1 with the dx rods. I got 14.3:1 using a z6 headgasket, and 13.7:1 using the b7 headgasket, I'm not sure which one you use with a mini-me. About 15:1 if you use the 2 layer y8 gasket.
I'm pretty sure my calculations are correct, but its late and I'm tired.
shimmed VTEC
You mean oil pump?
How much money do you have into this setup?
-PHiZ
shimmed VTEC
You mean oil pump?
-PHiZ
superhatchbackbros
14
Oct 18, 2010 07:50 AM
