My drivetrain fell out!!!
Well, sort of...
Got tired of waiting for parts to build the drag motor for the Civic. And I was bored. And it's been too long since I have had an engine apart (at least 5 months!).
So here she is prior to the debauchery:
Here is the poor thing with no drivetrain
The car rides a little higher in the front after the radical diet plan:
The missing drivetrain:
Goodies going into the engine to make it all worthwhile (thanks to TodaSI)
More pics and dyno sheets to follow in the coming weeks.
Modified by b19coupe at 7:27 PM 4/22/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeR »</TD></TR><TR><TD CLASS="quote">too much time you have on your hands there
</TD></TR></TABLE> forreal..
but good luck
but good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">nice
FYI
Drivetrain
The combination of mechanisms connecting the engine to the driven wheels, typically the transmission, driveshaft, and differential in a rear wheel driven vehicle.
Powertrain
A name applied to the group of components used to transmit engine power to the driving wheels. It can consist of engine, clutch, transmission, universal joints, drive shaft, differential gear, and axle shafts. Powertrain components are matched according to driver needs such as high torque, fuel economy, or convenience.
Your powertrain fell out
Modified by markpaco at 3:08 PM 4/19/2004
Drivetrain
Powertrain
Got the block back today from Benson's. Dan Benson does quality work.
Close up of the cylinder work:
Had a set of main bearings laying around for another motor that I am working on, so I got out the plastigage and installed the bearings. Looked at where they were, shuffled a couple and measured again, and they were perfect! Off to work tomorrow to pick up a set of rod bearings so the bottom end can be finished this weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">and why is that?</TD></TR></TABLE>
The wait
The wait
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 »</TD></TR><TR><TD CLASS="quote">
The wait</TD></TR></TABLE>
you mean all of like 20 miles,
Is your work hiring?
Seeing how you are getting tired of building your civic and now you need to throw money at your ITR, i need your job, haha
Good stuff, cant wait to see dyno results from both of your motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda »</TD></TR><TR><TD CLASS="quote">Nice ish bro.
Wanna see those dyno numbers!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote"> And whats with the short cut part? </TD></TR></TABLE>
I cut the AEM CAI and use a rubber joint to attach another intake. Car came with the CAI, I think that I will eventually try out the Mugen intake, when there is some extra money available.
This was supposed to be a quick budget build (I already had the pistons)
Modified by b19coupe at 10:24 PM 5/4/2004
So far so good. About 120 miles on the motor so far. I dropped a set of Toda 'C' cams in the motor too. I was going to run on the Skunk 2 Stage 2 cams and get a direct comparison before and after the piston install, but I could not resist the Toda cams. It took quite a bit of tuning to get the idle right. The car idled fine on the existing program with the Skunk cams, but died with the Toda's. Had to play with the throttle stop and TPS settings, and then play with A/F ratios and IAC duty cycles to get her to idle like stock again.
BTW Chad- the rods had to be machined to run the full floating Toda wristpins, which I did not realize until I went to put the pistons on the rods
Modified by b19coupe at 11:19 PM 5/9/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote"> edit: im alittle confused, did you have the stock itr block sleeved? then dropped in the (84mm?) toda pistons and C's?
Stock ITR block was bored to 81.5mm to accomodate the 81.5mm Toda pistons. I had the Skunk and Toda cams in my hand, and could not resist putting in the Toda cams. I have 'D's in my Civic, and the mid-range is unreal. I was going to put the stock head back on with just a valve job and light resurface, but it was not ready. So I put on a head that I had laying around ported by Portflow. Technical info about the pistons here:
http://www.todaracing.com/prod....html
