::fuel delivery problem??::
Old Apr 18, 2004 | 07:33 PM
spock_rocker's Avatar
memoryFAB.com representative
Default ::fuel delivery problem??::
what happens is this... i go to take off.. slowly let off the clutch and give gas, in this time the car will bogg like its going to stall. natural reaction is to give more gas, a couple seconds later it will take off like a bat outta hell.
i was told it was the cap and rotor. i changed those. thats not the problem. the only think ive noticed that would releave the problem is if i throw it in neutral and rev it really high and then continue on my way... any thoughts as to what it could be?? ok and the engine only has 12k miles so everything is fairly new
Old Apr 19, 2004 | 10:42 AM
taz77's Avatar
New User
Default Re: ::fuel delivery problem??:: (spock_rocker)
i dont' think it's fuel delivery problem. you'd most likely see a fuel delivery problem when you have a hard start, or takes a longer cranking time to start the car.
i would have said it's an ignition problem. somewhere in the lines of the spark plug wires. use an ohmmeter and check the resistance of the wires. i think most obd2 honda's specs for the wires are 25k ohms MAX... if any one of the wires shows more than that, replace the set. if any ONE or more wires fluctuates to a point that you can't read the numbers reliably, or shows OL... replace them immediately or else, it will lead to more expensive problems down the line.
Old Apr 20, 2004 | 05:35 PM
Default Re: ::fuel delivery problem??:: (taz77)
i was thinking about that too. the wires or maybe the plugs.. i'll look into that. anyone else??
CimorelliCRX
Apr 7, 2022 12:16 PM
GuitarPunk015
Jun 25, 2009 03:24 PM
4tika4
Mar 12, 2009 08:00 PM
Chaze*R
Aug 30, 2005 01:40 PM
92siracer
May 17, 2004 03:20 AM
