took the accord on a trip
heyjust took the accord on a 1000 + trip to minneapolis the car ran great and was great on gas but i changed out the 17s on teh front to stockers for the wear on them cause i have tons of camber and to lazy to buy a kit but what i am getting to is today on the way back it rained a little and wow did my rear end like to get loose man scared the livin **** out of me the front was fine jsut the rear end would hydro plain just wonderin if any one else has experieced this at all
91according, Where exactly are you located in ND? Is it close to Bismark ND or even further west? See I live in Minneapolis, and I often drive to my Grandma's house in Fargo, and that is only like 300 Miles (Give or take 50 miles
). Anyways what were you doing in the cities? And if it was your first time here, How did you like it?
Sorry as for the Hydro Plaining thing, What kind of tires do you have on the rears? If they are Falcon Azeniz or somthing close to that in tread, then that is your problem right there as to why you were slipping around. Also what HAccord96 said it could be that your tires in the back are just worn out, I would definately go check the tread on your tires and see how much is left.
). Anyways what were you doing in the cities? And if it was your first time here, How did you like it? Sorry as for the Hydro Plaining thing, What kind of tires do you have on the rears? If they are Falcon Azeniz or somthing close to that in tread, then that is your problem right there as to why you were slipping around. Also what HAccord96 said it could be that your tires in the back are just worn out, I would definately go check the tread on your tires and see how much is left.
eddieE
Jan 1, 2017 04:39 AM
