Changing MT oil (GSR), Can't find filler bolt? Help?
Old Apr 18, 2004 | 04:02 PM
B18CYAAA's Avatar
Default Changing MT oil (GSR), Can't find filler bolt? Help?
edit: delete
Old Apr 18, 2004 | 04:08 PM
Kendall's Avatar
Yes, it's the bolt with the indented square on it. To make changing it easier, after draining it, put the drain plug back in and pull the filler bolts as well as the VSS from the top of the transmission. Then just use a funnel from the VSS location and fill it until you start to see fluid drip from the filler hole. Then plug the filler hole and pour just a bit more in and then put the VSS back.
Old Apr 18, 2004 | 04:39 PM
B18CYAAA's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it's the bolt with the indented square on it. To make changing it easier, after draining it, put the drain plug back in and pull the filler bolts as well as the VSS from the top of the transmission. Then just use a funnel from the VSS location and fill it until you start to see fluid drip from the filler hole. Then plug the filler hole and pour just a bit more in and then put the VSS back.</TD></TR></TABLE>
awesome, thanks.
JDM-LuxurySport
May 6, 2010 07:30 AM
wariospeed
Mar 14, 2009 02:30 AM
Peter_404_21
Dec 30, 2008 08:54 PM
mnbv
Aug 1, 2004 11:51 PM
hb_racer
Mar 2, 2002 06:20 PM
