Sputtering
Old Apr 18, 2004 | 11:59 AM
jdmteg96's Avatar
Default Sputtering
I have a built GSR motor in a civic hb. When i go full throttle the car chokes out and the check engine light comes on. The car also sputters alot. What could these problems be???
Old May 7, 2004 | 02:06 AM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Default Re: Sputtering (jdmteg96)
Did you ever figure out what the problem was, I would be curious to know what it was causing this...
Old May 7, 2004 | 07:48 PM
jdmteg96's Avatar
the tps sensor is what kept it from going past a certain rpm when i floored it. Like i would floor it and then it would choke out at about 4 grand...
Old May 9, 2004 | 08:28 PM
DragInteg's Avatar
Obviosuly, the problem is solved if you diagnosed it. Good to hear
Old May 10, 2004 | 08:36 AM
jdmteg96's Avatar
Default Re: Sputtering (DragInteg)
if you unplug the tps sensor it will quit choking out but the best thing to do is probably just replace it. i'm guessing you could probably mess something up by just unplugging it
ochumi
Jun 19, 2019 03:51 AM
realmike15
Honda Civic (2001 - 2005)
Nov 12, 2010 09:38 AM
jaredvabeach
Jan 20, 2009 05:59 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
SIK IN DA HED
Nov 21, 2002 03:21 PM
