Help with the Lower Control arm + Steering knuckle
Old Apr 18, 2004 | 10:34 AM
LOWNSLOW's Avatar
Default Help with the Lower Control arm + Steering knuckle
Modified by LOWNSLOW at 8:00 AM 7/18/2004
Old Apr 18, 2004 | 11:03 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Help with the Lower Control arm + Steering knuckle (2Slow2Run)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Slow2Run &raquo;</TD></TR><TR><TD CLASS="quote">Ok I think it requires a ball joint puller. Where can I get the tool? Auto Store ? Hardware Store? sorry</TD></TR></TABLE>
You pretty much figured it out all by yourself. And to help you make the right decision, a ball joint puller is what you need and you can buy that at most local automotive stores. They have two kinds BTW (to my knowing)... the first is the hammer type, where you stick the fork in between the joints and hammer to get them out, the other is a clamp type puller. I would recommend the 2nd one.
-NRG
Old Apr 18, 2004 | 11:06 AM
dannylDAsport's Avatar
Default Re: Help with the Lower Control arm + Steering knuckle (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
-NRG</TD></TR></TABLE>
its called a pickle fork.
Old Apr 18, 2004 | 08:30 PM
stumpyf4's Avatar
Next time just unscrew the castle bolt a bit (maybe 1/4") and hit the bolt with a hammer. Couple of wacks will do it. If you completely remove the castle nut you run the risk of damaging the threads or having the knuckle and control arm spring away from each other.
Old Apr 19, 2004 | 01:35 AM
Stewie's Avatar
Default Re: Help with the Lower Control arm + Steering knuckle (stumpyf4)
some people remove the axle by unbolting the LCA from the body.
Old Apr 19, 2004 | 05:56 AM
Arsenal's Avatar
Default Re: Help with the Lower Control arm + Steering knuckle (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">some people remove the axle by unbolting the LCA from the body.</TD></TR></TABLE>
Crx_Civic
11
Oct 20, 2007 04:10 AM
itsjdmbradyo!
Oct 4, 2006 01:31 PM
novic3
Aug 19, 2006 08:34 PM
ricebowl
Oct 11, 2005 11:39 PM
llW0PllNefRex
19
Nov 18, 2003 07:40 AM
