What is the name of this part?
Old Apr 17, 2004 | 06:45 PM
Nitehawk's Avatar
Default What is the name of this part?
I have a 1995 Accord EX.
I'm looking to replace the switch/sensor that lets the car know that the rear passenger door is open. When I open the door, the dome light does not illuminate, and the indicator light on the dash does not light. The dash indicator works fine during the lamp check when I move the key to the Run position.
I pulled the rubber gasket off the part, and I pulled the switch. Inside, the spring is all deformed, and it won't open the switch when the door is opened.
What is this part called, and where would I get a replacement?
Old Apr 17, 2004 | 07:05 PM
Mike813's Avatar
Default Re: What is the name of this part? (Nitehawk)
im not really sure what youre looking for but try http://tasauto.com
or http://www.hondaautomotiveparts.com/ to get the name and part # of what you are looking for.
Old Apr 17, 2004 | 07:06 PM
StimpyBoy's Avatar
I had one starting to go bad, but I was able to just use some sandpaper and remove the buildup. I had some sort of carbon/green buildup as well. Worked like a charm after that.
Otherwise, I would hit up a junkyard for this one. I tried to find it once, everyone told me the dealer. Like hell I'd get that part from a dealership, they'll charge a fortune for it.
Old Apr 18, 2004 | 06:53 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nitehawk &raquo;</TD></TR><TR><TD CLASS="quote">
What is this part called, and where would I get a replacement?</TD></TR></TABLE>
Door jam switch. Honda sells them.
sgull
Oct 2, 2013 07:52 AM
19Accord97
Mar 9, 2012 04:50 PM
jaysin04
Nov 22, 2008 12:44 AM
delguiner
Oct 5, 2005 09:19 AM
