Ls engine swap
Old Apr 17, 2004 | 01:38 PM
Eg6_RcR's Avatar
Default Ls engine swap
Is this a good deal 92 LS swap for $400 comes with ecu, aftermarket headers, and axles. I still need motor mounts, tranny, engine harness and shift linkage. Is this a good deal for a 92 LS with 100k? Compression is still good 180 all across they guy also recently did a valve adjustment. Forgot what he said. It still runs strong.
Old Apr 17, 2004 | 01:45 PM
Newman's Avatar
New User
Default Re: Ls engine swap (Eg6_RcR)
Well, it's OBD-1 so you don't have to worry about the sensors or plugs, if it's going into a OBD-1 car. But you didn't mention what kind of car or what year it is that it's going into. If it's a 92+ Civic, you can use the cable tranny with a hydro-cable conversion kit (like the HCP EG-18C or EK-18C if an EK chassis), and use the ECU and everything else for it. But you will have to switch the mounts & brakets, and the shift linkage if going into a newer Civic or Integra.
Old Apr 17, 2004 | 02:11 PM
Eg6_RcR's Avatar
Default Re: Ls engine swap (Newman)
oh yea my bad. yea its going into a 92 civic. is $400 cheap for the engine with 100k.
Old Apr 17, 2004 | 02:12 PM
SprayinCX's Avatar
thats what i paid for mine. from what i can tell that is the going price.
Old Apr 17, 2004 | 03:13 PM
Eg6_RcR's Avatar
Default Re: Ls engine swap (SprayinCX)
thanks
Old Apr 17, 2004 | 03:15 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I'd try to find a hydro B series tranny. I'd particularly look for newer models with lower mileage, because tranny rebuilds are expensive even if you do all your own labor.
mrod1985
Feb 18, 2008 02:25 PM
92CxHatchback
Sep 8, 2003 07:01 AM
flat-blk-HB
Aug 27, 2003 03:12 PM
integraracing91
May 19, 2003 06:22 PM
