S2000 oil filter vs. stock one
Old Apr 17, 2004 | 01:35 PM
RedRacerCivic's Avatar
Default S2000 oil filter vs. stock one
I did an oil change yesterday and bought a Toyo S2000 oil filter for my d16a6. Whats so special about this filter? Its obviously bigger than my OEM oil filter, I didn't know that these were the same size of the older OEM honda filters that were produced about 6 months ago. Should I go back to ordering a correct(smaller) filter vs the hyped up(bigger) s2000 filter?
Old Apr 17, 2004 | 01:59 PM
crxgator's Avatar
Default Re: S2000 oil filter vs. stock one (RedRacerCivic)
because it filters better...its the same exact filter as the green HAMP ones...where as the new honda oil filters are made by fram...
Old Apr 17, 2004 | 02:27 PM
kim_2_da_chee's Avatar
Default Re: S2000 oil filter vs. stock one (crxgator)
the s2k filter is the same size as d16a6? (thread / the rubber o-ring gasket diameter..)
Old Apr 17, 2004 | 02:48 PM
spaceman's Avatar
looks to me like the inner diameter threads in the middle are smaller on the filter on the right,basically what im tryin to say is will it fit?..the gasket looks the same size so it should seal the same and a bigger filter is better(usually)..
Old Apr 17, 2004 | 03:01 PM
EG8R's Avatar
Default Re: S2000 oil filter vs. stock one (spaceman)
It will fit. The only HONDA filter that is different is for the 84-87 Civic/CRX....
Old Apr 17, 2004 | 03:07 PM
yea it fit just like my old one, in the picture that little hole in the middle is internal, not the threaded hole.
TurboTeG4
Acura TSX
Dec 11, 2013 12:14 PM
HyphyBB6
Oct 21, 2008 09:40 PM
rohec04
Aug 7, 2007 10:11 AM
vlballa
May 7, 2007 04:58 AM
HamiltonRex
Oct 10, 2004 07:00 PM
