Your opinions on Honda OEM oil filters vs. aftermarket ones
Old Oct 29, 2001 | 05:30 PM
Rah Rah's Avatar
Default Your opinions on Honda OEM oil filters vs. aftermarket ones
I was on another Honda board and they were discussing the quality of Honda filters vs. aftermarket ones. It seems that FRAM has a bad rap. What are your thoughts on the various brands that are out there like Puralator, NAPA, FRAM, etc..?
Old Oct 29, 2001 | 05:38 PM
fixhondas's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (sando112)
I highly prefer the Honda filter- If you really want to now the difference- cut them apart- you'll see. Most other filters have paper thin casings- like valvoline instant oil leak uses. They put them on super tight and when you try to remove them- they crush and leak all over your shoulder. Bastards!!! Also note, the Honda filters from Canada are really light- like they didn't put something in them- I haven't figured that one out yet. As for most parts for your Honda- only use HONDA parts- I can not stress this enough.
Old Oct 29, 2001 | 05:44 PM
FLIP2daMaX's Avatar
true-true...honda filters is prefrable, but da price at da dealers iz ludicrous after a while...*****' add up
go to manchester honda they got a package deal for 10genuine oil filters for $40
instead of $8 per fokin filter
[Modified by FLIP2daMaX, 9:45 PM 10/29/2001]
Old Oct 29, 2001 | 06:34 PM
CardDealer's Avatar
Banned
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (FLIP2daMaX)
Modified by CardDealer at 4:26 AM 11/16/2006
MattG's Avatar
New User
I use Mobil 1. There was a link somewhere that showed a test of all the filters cut apart. Most are all Fram or Purolator. Mobil 1 was the best of the test. I will look around for the link.
Old Oct 29, 2001 | 06:39 PM
MattG's Avatar
New User
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (MattG)
http://www.frankhunt.com/FRANK/corve...lterstudy.html
http://www.theautochannel.com/e_about/filters.html
sorry its a ford site. http://www.shoclub.com/lubrication-o...n-oilpart5.htm
Old Oct 29, 2001 | 06:44 PM
JSTOCK's Avatar
I use Mobil 1 as well.
Old Oct 29, 2001 | 06:45 PM
Roach2k's Avatar
New User
i always use WIX... for my oil and tranny filters. gf's dad owns an auto parts store, he used to sell FRAM stuff but he says wix is the best one out right now.
Old Oct 29, 2001 | 08:06 PM
HXMan's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (Roach2k)
I use mobile 1 oil, and bosch filters. Seem to work quite well together.
Old Oct 29, 2001 | 09:27 PM
egghead's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (HXMan)
I use Mobile 1 synthetic oil religiously, But the filters are just too damn expensive. Locally around here they go for 12 bucks a pop. The oil is already expensive enough so I just stick with Honda Filters. Might switch to HAMP, but I forgot how much those go for.
[Modified by egghead, 10:27 PM 10/29/2001]
Old Oct 29, 2001 | 11:03 PM
nfn15037's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (egghead)
ANyone tried those K&N oil filters? Ive been using those for the past few oil changes and noticed considerably less crap in the oil when drained when compared to the Honda filters.
Old Oct 30, 2001 | 02:03 AM
Dirt's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (nfn15037)
Purolator Pure One w/ Mobil 1 5w30
Old Oct 30, 2001 | 04:26 AM
Aceman64's Avatar
>I was on another Honda board and they were discussing the quality of Honda filters vs. aftermarket ones. <
did anyone else catch that one the first post? there are other sites besides HT? hehe. i surf over to the sometimes, but not nearly as much as i come here.
i only use honda filters and Mobil 1 oil. the otheres that are affordiable are crap and the k&n are too much along with the mobil 1 filters.
Old Oct 30, 2001 | 05:41 AM
Buzzbomb's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (Aceman64)
I use Castrol Max Pro Plus. It runs 5 bucks and claims 50% more particle filtration than leading competitor. I'm sure it's as good as the mobil 1 filter or the OEM filter. Mabey I'll cut the 2 apart to compare.
Old Oct 30, 2001 | 06:25 AM
unFOB4U's Avatar
I bought a **** load of honda filters awhile back cause i had a discount coupon. Before I always used Fram, but when I put an OEM filter in my car just seemed to run better , I dunno if it's cause of the filter, or just doing a regular oil change ( I change my oil at regular intervals )
Old Oct 30, 2001 | 07:18 AM
boosted3g's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (unFOB4U)
I perfer the honda filter just because when you grab it with the filter pliers they dont smash at all like most aftermarket filters.
Old Oct 30, 2001 | 07:33 AM
Dr Pooface's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (boosted3g)
Fram=****
Do not use fram filters!!!!
They are cheap for a reason.
[Modified by Dr Pooface, 4:33 PM 10/30/2001]
Old Oct 30, 2001 | 07:51 AM
FLIP2daMaX's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (Dr Pooface)
like i said up top i stick to HONDA OEM filters...and found them for a deal at manchester honda for $40 for 10 filters.... all i need now iz the fockin washers for the dam drain plug...any clue as to where i can find dat ****?...
Old Oct 30, 2001 | 08:35 AM
DragII's Avatar
25 Year Member
I used Fram for a while, never had any probs with em.
Old Oct 30, 2001 | 09:55 AM
Suprdave's Avatar
A Washer always comes with the Honda Filter and I throw it away...Is it for the drain Plug?
Suprdave
Old Oct 30, 2001 | 10:21 AM
egghead's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (Suprdave)
Shoooot, Honda always charges me for those washers. They dont come with the filters (well not for me anyway). Like 27 cents or something.
Old Oct 30, 2001 | 10:24 AM
DirtyLude's Avatar
Well, here's some real info. On the same line as the other oil filter study, but it looks at Honda OEM filters as well.
http://www.ntpog.org/reviews/filters/filters.shtml
Old Oct 30, 2001 | 01:45 PM
fixhondas's Avatar
Default Re: Your opinions on Honda OEM oil filters vs. aftermarket ones (DirtyLude)
Damn Canadians- I figured as much. A really good article. Japanese Hondas do come with Toyo Roki filters and the Filtech is much heavier than the Canadian. Thanks Dirty.
[Modified by fixhondas, 9:37 PM 10/30/2001]
Old Oct 30, 2001 | 01:56 PM
Rah Rah's Avatar
I bought a couple of Honda OEM filters and they cost me about 4 bucks and some change each. I get them at my local Acura dealer.
Old Oct 30, 2001 | 03:42 PM
mrlegoman's Avatar
That is an awesome link!! Thanks DirtyLude!!!
