Another A/C question
Old Apr 16, 2004 | 11:10 PM
Greasemonkey's Avatar
Default Another A/C question
I am trying to put A/C on my EK with a 96 LS motor. I just bought me a DEL SOL DOHC VTEC Bracket with a P30 stamp on it. I have not try to bolt it onto my compressor but I had put the the DEL SOl Bracket and my Bracket on the side and it does't look like the holes where the A/C compressor mount to it is the same.
Also as for the pulley, since I got it from honda it does not come with a Pulley. Do I need to get a new pulley with all the bracket?
thanks for all your help!!
Old Apr 16, 2004 | 11:49 PM
zensoku207's Avatar
Pretty sure the p30 AC mount is different. It will only bolt into 3 of the holes on the LS block. I think its where the headers are different on vtec and non-vtec cars.
The mount will still hold the compressor, but only 3 of the bolts instead of all 4.
And yes, you will need a pulley to run the compressor.
Old Apr 17, 2004 | 04:08 AM
2lua's Avatar
Default Re: Another A/C question (Greasemonkey)
i think you have a wrong ac braket. it should be p54.
Old Apr 17, 2004 | 09:02 AM
Is the P54 the 99-00 SI one?
Old Apr 17, 2004 | 11:45 AM
zensoku207's Avatar
You need the GSR one I believe.....unless there is an LS one with AC.....
Old Apr 17, 2004 | 03:13 PM
bankhead83's Avatar
you need a p54 bracket not a p30. I just put ac on my hatch with a gs-r swap and I used a p54
Old Apr 17, 2004 | 04:02 PM
What car does the P54 came out of..
Bankhead83, what year is your car? I am trying to use my DX compressor with my LS motor..
Old Apr 18, 2004 | 09:02 AM
bump
GReatEDDY
Dec 4, 2006 09:00 PM
carsaregood
Feb 9, 2004 11:20 AM
Sleepin'
Apr 12, 2002 11:33 PM
LXguy
Feb 6, 2002 12:00 PM
