trying my slicks out for the first time
Old Apr 16, 2004 | 09:11 PM
londa hover's Avatar
Default trying my slicks out for the first time
tomorrow im trying my slicks out for the first time and i have no idea what to launch at. they are 20/8/14 how much air should i take out and what should i launch at? right now i have 205/55/15 toyo t1-s tires and gm rotas and i launch at 6500. and how wide is 205? isnt that about 8"?
Old Apr 16, 2004 | 09:19 PM
Default Re: trying my slicks out for the first time (londa hover)
by the way i got a gsr
Old Apr 17, 2004 | 05:56 AM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">tomorrow im trying my slicks out for the first time and i have no idea what to launch at. they are 20/8/14 how much air should i take out and what should i launch at? right now i have 205/55/15 toyo t1-s tires and gm rotas and i launch at 6500. and how wide is 205? isnt that about 8"?</TD></TR></TABLE>
Talk to wil, he can help you on M/T
Exospeed Racing Products: "Honest Work, Done with Pride"
http://www.exospeed.com
exospeedCRX@yahoo.com 818-355-6156
John@M&H-Hashims
Old Apr 18, 2004 | 05:09 PM
what kind of 60ft times should i get with a 14.7 w/slicks on my gsr?
Old Apr 18, 2004 | 05:41 PM
NOrwayGT's Avatar
i have 205 on my stock rims. my rims are 6 and a half inches wide
Old Apr 18, 2004 | 09:00 PM
Jokerluv's Avatar
just heat them up real good and go at it... just launch diff way to get the feel of them
Old Apr 18, 2004 | 10:21 PM
Hondog's Avatar
Default Re: (Jokerluv)
So you want to know how much air and what sort of 60ft's you'll run on a 20-8-14 slick.. I would say run between 7-10psi and you'll run around 1.8 60ft's on road tyres I'd run around 14-20psi and hope for 2.0-2.3 60ft depending on your suspension, power, car weight..
But I ran 2.1 60ft's on 205-50-15 road tyres in a ZC powered EF7 crx and ran 14.6 1/4's at 95-98mph
Old Apr 19, 2004 | 08:14 AM
Gorm's Avatar
Default Re: (Hondog)
try 12-14 psi. I wouldnt go any lower or you could bent a wheel or roll the bead off the rim. I would say 1.9 60ft depending on your suspension.
Gary
Old Apr 19, 2004 | 01:26 PM
Default Re: (Gorm)
what suspension is the best for launching? i just have coil overs.
Old Apr 19, 2004 | 02:32 PM
Hondog's Avatar
Default Re: (londa hover)
I think alot of that depends on if you have traction bars etc made up for your cars.. But you want the back as hard as you can get it really, and the front needs to be low and adjustable so you can spend a day changing the set-up to find the best setting for your car..
Old Apr 19, 2004 | 05:46 PM
whats a traction bar? is that a strut bar or what? and do you think a 1.8 60'ft. is still possible with coil overs?
Old Apr 19, 2004 | 08:20 PM
and what should my 60'ft. be with a 15.5@91??
Old Apr 20, 2004 | 10:46 AM
b u m p
ericlee303
Feb 23, 2007 03:06 PM
BEEYOND
Dec 4, 2004 12:06 PM
Chiller
Jun 30, 2004 04:15 AM
ekvtec831
May 10, 2004 09:11 AM
Cyber ITR
Apr 21, 2003 04:54 PM
