obd question....searched already
hey i searched and im still confused a little....ok i got a 95 gsr swap and im droppin it into a 96 hatch....i want to use the obd1 dizzy and obd 1 ecu....wha do i have to do...as far as i know i have to re-wire the dzzy,alternator, and get a jumper. help needed thanks
well the dizzy is easy. you just need to repin it.
i would post a picture up for you but my computer is still all funky. i think it hates my camera.
but as for the ecu just buy you a odb2 to odb1 harness. i think you can get them for $75 and up.
back to the dizzy ?. if you look at the plug that has two wires in it. i think it is the black wire with a white stripe. pull it out of the connecter and move it to the empty space on the plud with the other 8 wires.
if i can get my computer to work i will take a picture of the one i did.
ok koo thanks sprayincx.....post the pics up. yeah i got my obd1 gsr swap today. i just need my mounts and the info of the obd stuff to drop it in ....
see that black with yellow stripe wire. you have to pull it out. get the also if you can.
take out that white cap with a small flat head screwdriver
then put it in this hole that has nothing in it.
as for the other plud don't worry about it and don't forget to put back in the white clip that holds all the wires in.
Ghett0_ed
Feb 10, 2009 07:59 PM
clean-jdm-ek
Aug 24, 2005 12:33 AM
