Civic Si(R) throttlebody bolts on ITR intake manifold?
Does the B16A2 throttlebody work on the Type-R intake manifold? Sensors, throttlepulley, etc... bolt on completely?
Thanks in advance
Thanks in advance
I would assume so.
Since the ITR manifold bolts onto a b16 head, most wouldnt purchase the TB seperately as well.
Just an assumption.
Just an assumption.
It does fit, but the inner diameter of the b16a TB is 60mm, while the ITR manifold receives an ITR TB at 62mm. You will have to bore out the b16a TB to 62mm or larger in order to avoid an air flow obstruction from occuring.
