Import Builders anyone suggest
Old Apr 16, 2004 | 06:07 AM
k_bster24's Avatar
Default Import Builders anyone suggest
Importbuilders.com (Jeff) seem like they have quality work i was just wandering if anyone would suggest them for building a block for me. Does anyone use there products and have u had good results with them??? Thanks
Old Apr 16, 2004 | 09:01 AM
eRACING's Avatar
Default Re: Import Builders anyone suggest (k_bster24)
IB
Good Products, Good Knowledge, Good Results
Old Apr 16, 2004 | 09:10 AM
Rick Solis's Avatar
Old Apr 16, 2004 | 01:08 PM
AllMotorMadness's Avatar
IB=JERRY BUILT
Old Apr 16, 2004 | 01:12 PM
Rob Dizzle's Avatar
Default Re: Import Builders anyone suggest (AllMotorMadness)
yeah its not jeff that builds the blocks
im pretty sure he sends them to jerry
jerry has built alot of good motors. as far as I know there are alot of happy customer with fast motors that have ib wisecos and hand built by jerry
they arent the only ones that build engines, and they prolly arent the best, but they have a proven track record.
learn about engine building and educate yourself and ask jerry and jeff alot of questions.
the more you know about whatever you are doing will usually lead to a better end result
Old Apr 16, 2004 | 02:02 PM
JBk24crx's Avatar
I got all of my bottom end parts from IB jeff , then I just took the block and the head and Jerry took care of building it.I will be to the dyno in about a month shooting for 250+whp for my 87 crx.im sure Jeff will hook you up.
Old Apr 16, 2004 | 08:38 PM
All Motor Rex's Avatar
Jeff and Jerry both good guys, and do good work.
Old Apr 16, 2004 | 09:50 PM
madtownhonda's Avatar
Default Re: Import Builders anyone suggest (All Motor Rex)
Old Apr 16, 2004 | 10:35 PM
EdBoon's Avatar
Default Re: Import Builders anyone suggest (madtownhonda)
Jerry is the man
hondaaccord94
Jun 17, 2006 10:40 PM
Engloid
Welding / Fabrication
Jan 29, 2005 09:24 PM
bracket 4 life
May 26, 2004 12:11 PM
TypeR0207
Apr 17, 2002 12:15 PM
