Honda S2000 Honda S2000
Oil cooler sandwich plate?
Old Apr 15, 2004 | 07:43 PM
THE GAME IS THICK's Avatar
Default Oil cooler sandwich plate?
My friend had a new engine put in by honda and they let him keep the old short block. We got bored so we just started ripping pieces off of it. We noticed that between the oil filter and the block their was a plate that had a tube that looped into itself. I have seen oil cooler kits that had a piece similar to this. I was wondering if anyone knew what this piece did and if i can use it on a b-series engine. I will post pics up as soon as i get home from work. BTW: here is a pic from hondaautomotiveparts.com
its #10(COOLER, ENGINE OIL) and #11-(BOLT, OIL COOLER CENTER)
Im just checking if its compatible with a b-series engine and was wondering why it looped into itself?
-Brandon
Old Apr 15, 2004 | 08:48 PM
spirit R
Guest
Posts: n/a
Default Re: Oil cooler sandwich plate? (igotsol!)
it's exactly what you think it is and as long as you have the plate and the screw it's just like the GSR's set up
Old May 4, 2004 | 07:17 PM
TurboB18C1's Avatar
Well i did some research on your topic with a friend... but i dont know if the bolt looks to be un screwable from the block but judgeing from the image it should be able to come off since they have a sandwitch made for that already in the picture?? IT is number 15 on the pic that i dont know of... if it comes off or not... ?
Old May 5, 2004 | 02:46 PM
Default Re: Oil cooler sandwich plate? (TurboB18C1)
Thanks buntizzle, does anyone know how to remove # 15?
dth0ng69
Honda CR-V & Element
Jun 16, 2017 10:18 AM
RabbittZ
Oct 17, 2006 05:19 AM
asleepz
Jan 12, 2006 02:46 PM
THE GAME IS THICK
May 14, 2004 07:43 AM
Spoond TEG
Jun 21, 2003 04:39 AM
