277/175 torque b16 crx
Old Apr 14, 2004 | 03:47 PM
1gen crxer's Avatar
Default 277/175 torque b16 crx
ok if i get a vortech s/c with after cooler i will have 277hp with 175ft/lbs of torque, this is with every thing stock except the internals. ok now if i port and polish teh head will that make me break the 200ft/lbs of torque? or would i have to pnp the head and bore the block liek .20 or .30 to achieve my 200ft/lbs of torque? any in put is helpfull, also i was gunan go turbo but the reliablity of the s/c better and the power through all rpm ranges not just high rpm range!
Old Apr 14, 2004 | 04:57 PM
1gen crxer's Avatar
bump
Old Apr 14, 2004 | 05:08 PM
HumanResource's Avatar
Default Re: 277/175 torque b16 crx (1gen crxer)
Power from the Vortec isn't delivered evenly across the rev range
it's more linear,
I'd go all out and build the bottom end up.
Old Apr 15, 2004 | 02:20 AM
1gen crxer's Avatar
how im new explain how the vortech is linear would a jacksons racing sc be better?and how would i build the block up?
Old Apr 15, 2004 | 05:48 AM
ThefirstPACT's Avatar
Default Re: (1gen crxer)
If you want power that you can almost infinityly upgrade then go turbo. Your going to pay about the same anyways. But if you have your mind set on SC then you have your mind set! But weigh the options!
Old Apr 15, 2004 | 07:50 AM
hahahahhah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1gen crxer &raquo;</TD></TR><TR><TD CLASS="quote">also i was gunan go turbo but the reliablity of the s/c better and the power through all rpm ranges not just high rpm range!</TD></TR></TABLE>
I would personally say go turbo, but like buddy above my post said: 'if you have your mind set on SC then you have your mind set!'
here's a little something to help you decide
http://www.superchargersonline...ID=19
try reading that. there are millions of articles out there weighing the pro's and con's of turbos and superchargers. just stem past the honda-tech.com search engine for this one.
as for acheving those hp/tq ratings, you'd probably have better luck with responses in the Forced Induction discussion area of this forum.
-edmCRX
Old Apr 15, 2004 | 11:14 AM
slowpokesi's Avatar
Default Re: 277/175 torque b16 crx (edmCRX)
first off, where are you getting these numbers? 277/175, i have a buddy with a vsc on his 00 si and he only put 255 down and he has a bunch of upgrades,
your also aware that the vsc wont fit in a crx or civic with a b16a with the aftercooler,
you can do it without the aftercooler, but you sure as hell wont end up with 277.
the VSC is basically the worst of both the turbo and sc worlds. You get the parasitic losses of a supercharger with the peaky spooling hp dyno charts. The turbo is a much more efficient way to make power then a supercharger
Modified by slowpokesi at 2:24 PM 4/15/2004
Old Apr 15, 2004 | 11:17 AM
kshymkiw83's Avatar
Default Re: 277/175 torque b16 crx (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">
but the VSC is basically the worst of both the turbo and sc worlds. You get the parasitic losses of a supercharger with the peaky spooling hp dyno charts. The turbo is a much more efficient way to make power then a supercharger</TD></TR></TABLE>
Well put, this is what i have heard about the vortech unit as well.
Old Apr 15, 2004 | 12:38 PM
1gen crxer's Avatar
ok i did wanna go turbo but heard some **** saying sc is better for 1.6 1.8l motors and turbos are better and hav ebetter resaults on higher liter motors i will go turbo just want advise. and should i bore the block if i go turbo, or should i leav eteh block for its strength?
Old Apr 15, 2004 | 12:46 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
keep it 1.8 and builded it........rods pistons blue printed everything....TURBO owNs me....
Old Apr 15, 2004 | 12:51 PM
1gen crxer's Avatar
well i need more info i searched eveyr were though every things says supercharegrs are better liek that link says super chargers are better most magazines say they are too. but from forums and stuff people say turbos are better im so confused
Old Apr 15, 2004 | 12:52 PM
dgonzals's Avatar
well...u have a super charger...get a turbo now and see the difference...thats all i can say...
Old Apr 15, 2004 | 12:58 PM
1gen crxer's Avatar
dont have one looking to purchase either of the 2
Old Apr 15, 2004 | 01:00 PM
dgonzals's Avatar
oh, go with your insticts then...thats all i can say.....
Old Apr 15, 2004 | 01:30 PM
slowpokesi's Avatar
first of all what car is this going into,
if its going into a 1st gen i doubt you could get either setups in the engine bay paired with a bseries so this discussion is probalby pointless anyway.
turbos are better than superchargers hands down, besides all the vsc is a turbo, but its on a stick and its used in a diffrent way.
since everywhere you read says that supercharges are better than turbos why dont you post these articles so we can read them.
oh and better yet, next time nopi or nira rolls through your town go look at all the 8-10 second race cars, and tell me how many had turbos and how many had sc's
Old Apr 15, 2004 | 02:27 PM
1gen crxer's Avatar
take a look at teh link above i never stated one was better if i knew then i wouldnt be asking, second i am getting a 2g with a b16
Old Apr 16, 2004 | 05:41 AM
slowpokesi's Avatar
then get a turbo,
its will be better for you in the longrun, and you have alot more options, turbo kit and vsc is about the same price anyways so why not get the one thats going to net more power in the long run.
Old Apr 16, 2004 | 07:44 AM
91civicDXdude's Avatar
sounds like someone has been reading too much summit sport compact... if i remember correctly, thats the numbers they quoted for the vortech kit..
EGhatch33
Mar 20, 2006 11:37 AM
project dc2
Jul 27, 2004 06:43 AM
gutted
13
Feb 5, 2004 08:03 PM
PrecisionH23a
Oct 28, 2002 08:14 AM
AfEn808
Dec 12, 2001 01:47 AM
