car wont start
Old Apr 14, 2004 | 12:19 PM
drewek-9's Avatar
Default car wont start
did an mini me swap witha n y7 block y8 head and now car wont start. it wants turn over but seems like no spark from cap replaced distrbitor and wires same thing gap is all set sensors and everything is good any ideas to what can be wrong anyone have this problem ever ??? need help asap
thanks
drew --speedNmotion
Old Apr 14, 2004 | 12:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: car wont start (civichbturbo2000)
This is easilly the most often asked and unanswered question on Honda-Tech. Your cam could be 180 degrees off, your plugs could be bad, your distributor could be bad, your grounds might not be hooked up, your ECU could be bad, etc.
Try everything.
Old Apr 14, 2004 | 05:14 PM
drewek-9's Avatar
Default Re: car wont start (Archidictus)
i guess it was timing i had it set wrong so i re tdc it and now alost cranked up have to charge battery so it can get the full amount of cranking power
Hill4589
21
Jun 20, 2009 05:27 PM
gsrpedro
Dec 5, 2008 11:42 AM
Slink2000
Mar 17, 2006 03:03 PM
c-y-nickel
Mar 16, 2004 04:24 PM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
