I need help someone help me with this
Old Apr 14, 2004 | 09:43 AM
THE94GSR's Avatar
Default I need help someone help me with this
ok yesterday i took the car out everything was working fine i get in ther car at night to pull my window down and the damn window doesnt go down i try to lock the door and the power locks dont work either i check to see if i can adjust the mirrors and they work fine i go and check to see if can put the window down from the passanger side and it it works fine but the power locks arent working i woke up today and checked every fuse in the car and all the fuses seem to ok so what is the damn problem y cant i put my driver side window down or lock the car... someone please help me asap
Old Apr 14, 2004 | 09:50 AM
FlaN.'s Avatar
are you SURE your fuses are ok? take your driver's side door panel off and look for any loose connections. also, check to see if the actuators and window relay is getting power
Old Apr 14, 2004 | 10:13 AM
THE94GSR's Avatar
Default Re: (FlaN.)
yes i check all the connections and when i try to put the window down it makes a buzzin noise like its getting power to it but its just not going down also there has to be something else wrong cause the locks arent working...
Old Apr 20, 2004 | 12:50 PM
THE94GSR's Avatar
Default Re: (THE94GSR)
anyone else
Snailor Built
Jun 14, 2010 07:13 PM
buttsneeze
Apr 27, 2008 03:50 PM
Hondaholik
Dec 7, 2006 10:27 PM
int3gra07
Sep 15, 2005 05:52 AM
thenick
20
Jun 29, 2004 06:00 AM
