Getting EGR off!! 98 SH
Old Apr 14, 2004 | 09:20 AM
preludeSH's Avatar
Default Getting EGR off!! 98 SH
Is there a certain tool used to take off the EGR valve on a 98 SH, also how do you clean out the ports. thanks
Old Apr 14, 2004 | 09:39 AM
Behan's Avatar
Default Re: Getting EGR off!! 98 SH (preludeSH)
3/8" inch ratchet, 6 inch ext. and 12mm deep socket.
once you remove it use carb cleaner to remove the carbon, ensure the plunger moves freely and reinstall.
Old Apr 15, 2004 | 05:40 PM
delsolsir2's Avatar
dude what you need is a 1/4 drive short 12mm socket, a 6 inch 1/4 inch extension and either a 1/4 driver or use a 3/8 to 1/4 adapter if you need more leverage. the 1/4 short socket and 1/4 extension will give you the proper clearence you need
Old Apr 16, 2004 | 12:10 AM
b16hybridsol's Avatar
Default Re: Getting EGR off!! 98 SH (delsolsir2)
yea, the 1/4 drive will also break when you try to break the bolts loose, or it will break the tip off the extention, trust me done it many times. 3/8
Old Apr 17, 2004 | 06:38 AM
Daemione's Avatar
Default Re: Getting EGR off!! 98 SH (b16hybridsol)
I'm pretty sure that nothing 3/8" drive will fit around the EGR. Those bolts aren't too bad at all - 1/4" drive had no problem on mine.
Old Apr 18, 2004 | 04:36 AM
Behan's Avatar
Default Re: Getting EGR off!! 98 SH (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure that nothing 3/8" drive will fit around the EGR. </TD></TR></TABLE>
I'm 100% positvie 3/8" drive will fit. Sure 1/4" will work, but you definetly run the risk of breaking **** using the smaller drive.
Old Apr 18, 2004 | 01:35 PM
specalk's Avatar
Default Re: Getting EGR off!! 98 SH (Behan)
whats the purpose of cleaning it out and how often is it suppost to be done, also if its never been clean what can it possibly do, theres alot of people that block it off
Tensa_Zangetsu
Dec 20, 2007 07:29 PM
Legendaryyaj
May 5, 2006 07:13 PM
JSTOCK
Mar 20, 2002 05:29 AM
