Clutch Problem **NEED HELP**
Old Apr 13, 2004 | 11:54 PM
OSG 97 ITR's Avatar
Default Clutch Problem **NEED HELP**
All of a sudden I noticed a lot of free play in my clutch. Even if I have the clutch pressed all the way to the, I can't get it out of gear. When i was driving today and I downshifted to third from forth, with the clutch all the way down, all I got was grind. Is there anyway to adjust the freeplay? I did some searches but I didn't find any direct answers. Throw out some advice. peace
Old Apr 14, 2004 | 12:12 AM
B2FiNiTY's Avatar
Default Re: Clutch Problem **NEED HELP** (OSG 97 ITR)
Sounds like something wrong with the clutch itself rather than the adjustment.
Old Apr 14, 2004 | 05:31 AM
ericlee303's Avatar
Check your master or slave cylinder. My slave went last year, you will be able to tell if there is fluid leaking out of it.
In case you don't know, it's on the front of the tranny.
Old Apr 14, 2004 | 09:29 AM
OSG 97 ITR's Avatar
Default Re: Clutch Problem **NEED HELP** (ericlee303)
I jumped in my car this morning and tapped on the clutch and it just fell to the floor. I checked my clutch fluid level and it was below the min level. It looks like it is a leak. I'll get under the car today after work. damn
Old Apr 14, 2004 | 09:45 AM
Fac3Man's Avatar
Before you get under the car check around where the clutch pedal arm meets the firewall and see if you find any fluid there.
Old Apr 14, 2004 | 09:51 AM
OSG 97 ITR's Avatar
Default Re: Clutch Problem **NEED HELP** (Fac3Man)
i didn't really see any fluid... just grease from the piston.
Old Apr 16, 2004 | 05:02 PM
OSG 97 ITR's Avatar
Went to Acura... turned out to be leaky master and slave cylinders.
Old Apr 16, 2004 | 05:56 PM
mikestypeR
Guest
Posts: n/a
I hoped you check all the clutch fluid as well
Then replace the slave cylinder and the clutch master cylinder if all else fails then its the dam clutch
Old Apr 17, 2004 | 10:11 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Clutch Problem **NEED HELP** (mikestypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeR &raquo;</TD></TR><TR><TD CLASS="quote">I hoped you check all the clutch fluid as well
Then replace the slave cylinder and the clutch master cylinder if all else fails then its the dam clutch</TD></TR></TABLE>
Do you read?
1. He checked fluid level and it was below minimum mark
2. He went to Acura and they told him faulty master/slave cylinder- whats the deal with the names anyways...master and slave ....kinda messed up.
Before you have them change, unless you already had them, check the soft line from the master cylinder to the resevoir. I've seen those leak...tighten up, bleed clutch with fresh fluid and you're good to go
CraiGlOl
Jul 9, 2009 07:52 AM
evade_07
Dec 13, 2008 10:15 PM
hatchsi0485
Nov 21, 2005 06:13 AM
type_sml
Aug 23, 2002 12:53 PM
91DA9
Feb 5, 2002 07:57 AM
