anyone daily driving on Apex Pro N1 dampers?
Old Apr 13, 2004 | 10:43 PM
DC2*Integra's Avatar
Default anyone daily driving on Apex Pro N1 dampers?
im having hell of a time driving it on public roads. The car is bouncing around everywhere and it doesnt feel as safe as before. By the way, the spring rates it came with is i belive 18k in the front and 8k in the back. So my question is, do any of u guys daily drive with this suspension? If so, what are ur impressions? Oh yeah, let me add, i only have the front ones in at this time. The back setup is sprint springs with tokiko illuminas.
Old Apr 14, 2004 | 11:38 AM
D.CACO's Avatar
Default Re: anyone daily driving on Apex Pro N1 dampers? (DC2*Integra)
Put the rear set in, see what happens.
Yeah, 18K is going to be bouncy(springy*) in the front. I think the rates are based off of N1 japanese race track specs, not street. Are the rears really *only* 8k? I would think they would be atleast 10-12...
New springs?
Old Apr 14, 2004 | 11:57 AM
SuzukaBlueAP2's Avatar
Default Re: anyone daily driving on Apex Pro N1 dampers? (D.CACO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO &raquo;</TD></TR><TR><TD CLASS="quote">Put the rear set in, see what happens.
New springs?</TD></TR></TABLE>
18k as in 18,000 spring rates shouldn't bounce at all. That is as stiff as concrete.
You sure you don't mean 1800 rates in the front and 800 in the rear ? That would make more sense. Even then, it'll be like driving a 2x4 on the road. There is no give in those because they are made for racing. And race surfaces don't have potholes and uneven surfaces.
Also, do you have a Type R? Or did you change your lower control arms to accomodate for the difference ?
Old Apr 14, 2004 | 12:33 PM
D.CACO's Avatar
Default Re: anyone daily driving on Apex Pro N1 dampers? (ScreaminTeg)
[QUOTE=ScreaminTeg]
QUOTE]
Which makes them bounce. (A stiff bounce, maybe we have diff definitions of "bounce". Im not meaning "cut springs" bounce)
We have 20k fronts on our TEIN N1's (race only car) and I think these rates are super stiff- cant imagne them on the street, must be uncomfortable. We are going to dial down the rates on our susp, since the car would over-react to almost every surface detail on the track.
18K spring rates on a street car is super overkill IMO. But, obviously, it is driver preference.
Old Apr 14, 2004 | 12:57 PM
Yeah, I think we were just defining "bounce" differently. But yes, those kind of springs rates are ludicrous to run on the street. Even when you start to near the 800 mark on springs rates, things tend to get a little rough on everyday roads.
But, like you said, driver preference. I still want to know if he has a Type R or if he is changing lower control arms. Because the N1 damper is produced for the Type R only. And the only way to fit it in the LS/RS and GS-R suspension is to swap parts.
Old Apr 14, 2004 | 01:52 PM
D.CACO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
But, like you said, driver preference. I still want to know if he has a Type R or if he is changing lower control arms. Because the N1 damper is produced for the Type R only. And the only way to fit it in the LS/RS and GS-R suspension is to swap parts.</TD></TR></TABLE>
Oh, THATS RIGHT! You meant the rear LCA's... (I have a GSR and almost considered this exact suspension upgrade). I'm sure he swapped it.
Old Apr 14, 2004 | 02:10 PM
Also, do you have a Type R? Or did you change your lower control arms to accomodate for the difference ?</TD></TR></TABLE>
im pretty sure its 18,000k instead of 1,800k. Its soooo stiff it hopps instead of bounce. No i do not have a type r, im in the market for the lower control arms right now. thats why i only have the fronts in.
Old Apr 14, 2004 | 09:22 PM
hopefully ill get the backs in soon. and i will let u know how it feels. If it still sucks, im probably going to change the spring rates to 8k front, and 5k back
Old Apr 21, 2004 | 05:14 PM
Andres-eh2's Avatar
have u changed the damper settings?
i just got my set, which way is stiff or soft?
&lt;---- cant read the jap. instructions
Old Apr 27, 2004 | 10:33 PM
Default Re: anyone daily driving on Apex Pro N1 dampers? (Andres-eh2)
i forgot which way is soft and stiff. best way to find out is drive it after ajdusting it all the way to one side. and then drive it again after adjusting it all the way to the other setting. ull feel the stiffness
an2ny888
Dec 14, 2005 11:47 AM
xmilanoredsix
Dec 14, 2004 09:00 PM
POLLO
Oct 12, 2002 08:32 PM
eg6madness
Aug 15, 2002 03:48 PM
Cyrio
Sep 25, 2001 08:56 PM
