PLEASE HELP ME idle is messed up plus gauges/turn signals wont work!!
Old Apr 13, 2004 | 08:57 PM
exotik4doorcivic's Avatar
Default PLEASE HELP ME idle is messed up plus gauges/turn signals wont work!!
ok i got this car about 5 months ago and when i got it, it had a dx engine with a blown head gasket, and the idle would go up and down from 1000 to 1500. at first i thought it was the map senser but i replaced that and filled it with coolent and it didnt fix it, so thinking it was the head gasket that was causing idle i put in a d16z6
now here's the problems
when i turn the car on it will idle for about 3 seconds go up to 1500 and then die, but if you hold to peddle and keep it idled until it warms up it will either idle very low (about 6500) or the idle will go up and down,
also,
a wire that went to my fuel pump relay fried and after i replaced that wire my gauges, turn signals, check engine light wont work, and odometer
BUT
everything that will work without the key on will work
ei the dome light,headlights, gauge lights, and hazards
can you guys help me??
Old Apr 13, 2004 | 09:48 PM
Default Re: PLEASE HELP ME idle is messed up plus gauges/turn signals wont work!! (exotik4doorcivic)
can anyone help me?
Old Apr 14, 2004 | 03:07 PM
i read from red del sol si that he is having the same problem, was it ever solved??
BigDaddyRich
Jan 11, 2012 08:11 AM
b20eg9daddy
Oct 25, 2008 12:37 PM
Homotor
Jan 29, 2008 06:22 PM
