im a moron, and need help
Old Apr 13, 2004 | 08:14 PM
JG5's Avatar
JG5
Default im a moron, and need help
i recentls had a little problem with my car, a bypass radiator hose blew and sprayed pretty hot coolant all over everything under the hood, now my engine sounds like hell at low rpms and seems to loose power at low rpms, so i took the distributor apart and got all the coolant out of there and replaced the spark plugs, but i dont know what else could be wrong, any ideas on what i could do
one more thing the check engine light is on and wont go off, do i have to reset something maybe?
any help would be great!
Old Apr 13, 2004 | 08:25 PM
GoQkRaCeR's Avatar
Default Re: im a moron, and need help (JG5)
drain all the collant out... take out the main bolt of the plug to drain it
change your oil let it drain totally dry and put about a quart in and then drain it again.
spark plugs
distributor.. dry it out.. let it sit a good few hours.. make sure ur timing is correct.
reset the ecu also.
if that dont work.. do a leak down test compression test
maybe tear the head off
could be a exhaust leak somwhere also
Old Apr 13, 2004 | 10:37 PM
95 integra's Avatar
Default Re: im a moron, and need help (GoQkRaCeR)
get the ECU code. If you're getting the code it means there is a problem. Once you fix the problem then your CEL should go away. Also note that you will need to reset the ecu after you do this or it will store it in the memory and come up next time you pull a code. Atleast thats how it worked on my 95.
Old Apr 14, 2004 | 01:11 AM
WhoisDan's Avatar
Congrats on your first post.
Old Apr 15, 2004 | 04:04 PM
JG5's Avatar
JG5
thank you all very much!
Old Apr 15, 2004 | 04:10 PM
JG5's Avatar
JG5
one more thing, how do i reset the ECU?
Old Apr 15, 2004 | 04:25 PM
GG-SquadDB's Avatar
Default Re: (JG5)
take off th eneg abttery cable and let it sit for 15mins the start it and let it come down to idle speed and u should be good
Old Apr 16, 2004 | 02:01 PM
JG5's Avatar
JG5
thank you very much!
Old Apr 16, 2004 | 02:18 PM
RayB's Avatar
You might want to inspect the coil, rotor, and electrode tips in the cap for corrosion just to be on the safe side.
Old Apr 16, 2004 | 07:11 PM
IVI's Avatar
IVI
Default Re: (RayB)
if you tkae off the rotor , remmeber the position it was in. you have to install the new one exactly the same as the old one was. there should be a rubber gasket on the distributor cap also, check to make sure you have one. take out all the plugs and crank the motor to make sure no standing water is in any cylinder. taking the plugs out and cranking will shoot the water out of the chamber. if its not driving fine dont force it. you could end up breaking something.
Joeski089
Honda CR-V & Element
Sep 4, 2017 07:20 AM
waxbunny
Apr 28, 2005 06:01 PM
civicracer1993
Aug 1, 2004 01:30 AM
hondura
Dec 15, 2002 01:28 PM
