civic transmission compatibilty
Old Oct 28, 2001 | 05:38 PM
tcc1577's Avatar
Default civic transmission compatibilty
Will a 2000 civic si 5-spd/differential bolt up to a 1989 civic si. Both are 1.6 motors.
Old Oct 28, 2001 | 08:00 PM
Phatwhippin_CRX's Avatar
Default Re: civic transmission compatibilty (tcc1577)
No, the 200 CIvic Si, although a 1.6, is also a DOHC B series engine....
The 88-91 Civic/CRX Si engine is a D16a6, and the parts are not interchangeable between these two engines.........
Old Oct 28, 2001 | 08:26 PM
91ED7Si's Avatar
Default Re: civic transmission compatibilty (Phatwhippin_CRX)
Phatwhippin_CRX allready answered your question correctly..
so im just gonna ask what is the reason you are wanting to do this?
Old Oct 30, 2001 | 01:48 PM
tcc1577's Avatar
Default Re: civic transmission compatibilty (91ED7Si)
I road race my 89 civic and am looking for better gearing. Trying to save myself some money by doing this, rather than spending $1100.00 on a ring and pinion! Any ideas? Thanks.
Old Oct 30, 2001 | 04:00 PM
rioninja's Avatar
!1100!? ****. If your looking for wider gearing, try to find a tranny from a DX or HF. If your looking for closer gearing which i assume, the only thing closer would be a ZC tranny which can be had for a few hundred dollars tops. In this case, i think maybe you should just stick with your stock si trans and do some power mods instead. Get a used sohc cam for cheap.
Old Oct 30, 2001 | 09:07 PM
91ED7Si's Avatar
doesnt the zc have wider 1-5 gears and a closer final drive?
if you want wider gears put in the zc 1-5 if you want closer put in the zc final drive.
btw what do you mean by better?
these gears are about as close as they get for a factory can and the 2000 Si has wider gears even i believe.
[Modified by 91ED7Si, 6:09 AM 10/31/2001]
Old Oct 31, 2001 | 12:48 PM
tcc1577's Avatar
my goal is to install a final drive with a lower gear (higher numerical) Was hoping the 2000 si trans fit because it is a 4.40 final.
Not concerned with 1 thru 5. Engine has already been modified as much as class allows. Will also be installing an LSD
to improve acceleration off the corners. Last resort is to purchase a 4.73 final from aftermarket, at $1050.00 ! Thanks for your input.
Old Oct 31, 2001 | 12:50 PM
tcc1577's Avatar
Forgot to ask, what is the zc final drive ratio? where can i find this model trans?
Old Oct 31, 2001 | 01:25 PM
Mista Bone's Avatar
D Tranny Guru
ZC FD = DX FD
3.889
whitecvcb16
Jan 22, 2009 05:31 AM
whitecvcb16
Jan 21, 2009 02:56 PM
alupso
42
Nov 10, 2005 05:49 PM
dingusjt
12
Sep 25, 2002 11:18 AM
