Rotor Rotor
Old Apr 13, 2004 | 04:44 PM
Ape's Avatar
Ape
Default Rotor Rotor
what size is a stock 92 civic SI rotor?
Old Apr 13, 2004 | 04:51 PM
slammed_93_hatch's Avatar
Default Re: Rotor Rotor (Ape)
with or without abs (not sure if abs was offered in 92 but it does make a difference)
Old Apr 13, 2004 | 05:03 PM
Ape's Avatar
Ape
Default Re: Rotor Rotor (slammed_93_hatch)
With out
Old Apr 13, 2004 | 05:10 PM
Targa250R's Avatar
be professional
If you had searched, you'd have found that the non-ABS '92-93 Si hatchback front rotors are 9.5".
Old Apr 13, 2004 | 05:24 PM
Archidictus's Avatar
Unceasing Measure
I heard there was this thing called a "ruler" with a knockoff product being produced in conjunction called a "tape measure". Now, I'm not sure exactly what they do, but something tells me they'll give you a pretty accurate answer.
Old Apr 13, 2004 | 05:25 PM
Ape's Avatar
Ape
Default Re: Rotor Rotor (Targa250R)
Oh its a good thing i did search. Take a look at my sig befor you post about me searching. Anyhow.. my fronts are 10.5 or 10.3 what is that off of?
Modified by Ape at 7:23 PM 4/13/2004
Old Apr 13, 2004 | 05:26 PM
Ape's Avatar
Ape
Default Re: Rotor Rotor (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I heard there was this thing called a "ruler" with a knockoff product being produced in conjunction called a "tape measure". Now, I'm not sure exactly what they do, but something tells me they'll give you a pretty accurate answer.
.</TD></TR></TABLE>
IF i knew they were stock i wouldnt have posted but i wasnt for sure. and yes i did measure them. Smart ***.
Old Apr 13, 2004 | 06:22 PM
Ape's Avatar
Ape
Rotor boater
Old Apr 13, 2004 | 07:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ape &raquo;</TD></TR><TR><TD CLASS="quote">Oh its a good thing i did search. Take a look at my sig befor you post about me searching.</TD></TR></TABLE>
Apparently you aren't very good at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Anyhow.. my fronts are 10.5 or 10.3 what is that off of?</TD></TR></TABLE>
Again, if you had searched, you would have found that the following USDM Honda cars have 10.3" vented front rotors with a 4x100mm lug pattern:
- '92-95 Civic Si (with ABS)
- '94-95 Civic Si (non-ABS)
- '99-00 Civic Si
- '90-00 Civic EX
- '94-97 del Sol VTEC
- '90-01 Integra (except Type-R)
sandturtle
Aug 2, 2008 04:45 PM
y2kferari
May 1, 2007 11:48 AM
beer30hatch
Mar 3, 2007 10:36 AM
Ape
Mar 28, 2004 02:37 AM
Cee_mon
13
Nov 20, 2003 04:20 PM
