Engine Harness question
Old Apr 13, 2004 | 02:11 PM
P.M.Coupe's Avatar
Default Engine Harness question
I had a GSR swap in a 88 hf, i pulled the motor along with the harness attached. I then put the motor with the hf harness into a 91 si. Now the car will not start, is it the harness or something else. The motor will turnover, getting fuel and spark but just will not start. Suggestions are appreciated. Thanks.
Old Apr 13, 2004 | 04:28 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Engine Harness question (P.M.Coupe)
just a rule of thumb use the harness out of the car that you are swaping.. same harness same car
Old Apr 13, 2004 | 06:19 PM
jlicrx's Avatar
Default Re: Engine Harness question (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">just a rule of thumb use the harness out of the car that you are swaping.. same harness same car</TD></TR></TABLE>
right - you need Si harness - they are not interchangeable
bradennicely
Apr 25, 2010 04:36 PM
crxbomb
Dec 30, 2007 12:46 PM
v-tec maz
Jan 8, 2006 07:01 PM
Keith P
Mar 8, 2005 06:57 AM
