where to buy mount inserts??
Old Apr 13, 2004 | 01:53 PM
Nextelbuddy's Avatar
Default where to buy mount inserts??
i did a search and only found torque mount inserts. i want those as well. but i would liek to get mount inserts for the upper mount on the timing belt side and the top tranny mount. any ideas?
Old Apr 13, 2004 | 01:55 PM
elevatethis's Avatar
Default Re: where to buy mount inserts?? (nextelbuddy)
Energy Suspension for inserts
Jimfab.com for complete mounts (adds a lot of vibration in the car, but keeps that sucker still...)
Old Apr 13, 2004 | 02:01 PM
Default Re: where to buy mount inserts?? (elevatethis)
again i only saw mount replacment inserts for the lower torque mounts lol. i want the mount inserts for the 2 UPPER mounts. timing belt side mount and upper tranny mount.
if i cant find them is there some kind of strong silicone i can inject into the mounts them selves lol? like window weld or something?
Old Apr 13, 2004 | 02:11 PM
NonovUrbizniz's Avatar
Loved
Call ES... they do not sell the upper 2 inserts... neither does prothane if I remember correctly..
But when I called Energy Suspension they said that they were producing those mounts for another company... which by now should be selling them...
call e.s. for more info.
Just F.Y.I. the reason no one makes the inserts for those mounts is (according to the rep I talked to at energy suspension) they do nothing once the other three are installed. They would be for peace of mind only.
I don't know how true or not that is... but that's what he said.
Old Apr 13, 2004 | 02:34 PM
turboman's Avatar
If someone else has the link to the site I found this info on please post it. I can't remember where it was. Anyways.....
Get 3m window paste. It's basicaly a liquid polyurethane. Fill in the gaps with this stuff and let it dry. You will have a new solid mount.
Old Apr 13, 2004 | 03:57 PM
Default Re: where to buy mount inserts?? (turboman)
yea thats what i was talkin about. where can i find this window paste? home depot,lowes?
Old Apr 13, 2004 | 04:46 PM
turboman's Avatar
They sell it at auto parts stores. It's used for sticking windows in cars.
Old Apr 13, 2004 | 06:14 PM
lohatch's Avatar
http://www.homemadeturbo.com
has how-to's on doing your own poly mounts i believe. check it out
Old Apr 14, 2004 | 07:11 AM
Default Re: where to buy mount inserts?? (lohatch)
i found 2 types of 3M window weld. the one i think looked like the correct stuff is called 3M Window-Weld Super Fast Urethane: this can be found here:http://shop.store.yahoo.com/le....html
and the other is called 3M Window-Weld™ Resealant this can be found here: http://www.handsontools.com/st...=3950
i think the first one is the right stuff hence the name urthane lol. if it is then i think more people shoudl know about this as a alternative to buying expensive mounts or inserts since a tube is only abouty 9.99 and will fill ALL 5 mounts
Old Apr 14, 2004 | 07:21 AM
kadburry's Avatar
i think prothane makes the upper mount inserts
Old Apr 14, 2004 | 07:26 AM
esoterEK..'s Avatar
Default Re: where to buy mount inserts?? (kadburry)
Do you mean this ? this is a prothane from my engine.
Old Apr 14, 2004 | 07:30 AM
Default Re: where to buy mount inserts?? (EGkwazhimoto)
yea i mean those mount inserts. but i couldnt find anyone that had them. where cna i find those inserts? and do they make the inserts for the top tranny mount as well? do they come in other colors like RED?
Old Apr 14, 2004 | 08:24 AM
IS3Fifty's Avatar
seems like making your own mounts stiffer with the goo would be the best option.
Old Apr 14, 2004 | 08:26 AM
Default Re: where to buy mount inserts?? (TODAeg6)
exactly what i was thinking. not as bling becasue you cant se the GOO but in return yuo get a much more solid functional mount that will prevent wheel hop much better which is the culprit of most broken axels at the track.
Old Apr 14, 2004 | 09:06 AM
GReddy SI's Avatar
https://honda-tech.com/zerothread?id=713941
Old Apr 14, 2004 | 10:21 AM
Greasemonkey's Avatar
For those that have done the polyurethane insert or filling, please let me know how it work. This look looks like it's simply the best solution to not buying $600 mounts.
Old Apr 14, 2004 | 10:52 AM
JDMs1eeper's Avatar
Im glad i found this thread, it'll save me some $$ I was gonan spend this weekend
Old Apr 14, 2004 | 12:01 PM
NotUrAvgSi's Avatar
go to optauto.com they have cool shizle.
Old Apr 14, 2004 | 12:13 PM
ITSTOCK's Avatar
Default Re: where to buy mount inserts?? (Typesi2nv)
how long do u have to let that **** dry for? i heard it takes weeks?
Old Apr 14, 2004 | 12:29 PM
lohatch's Avatar
Default Re: where to buy mount inserts?? (ITSTOCK)
i say a guy make some and let them dry for 24 hours. cant remember what site i saw it on tho. eventually i will do this to mine
Old Apr 14, 2004 | 12:34 PM
BeerMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">i say a guy make some and let them dry for 24 hours. cant remember what site i saw it on tho. eventually i will do this to mine </TD></TR></TABLE>
http://importnut.net/motormount.htm
was it this?
Old Apr 14, 2004 | 02:05 PM
Loved
I'd say doing them yourself is the cheapest... not the best option...
when i did the inserts... it still sucked till I replaced 2 of the stock mounts that were no good... the inserts just brace the stock mount... if the stock mounts are shot then it's not gunna do what it should by just slapping in inserts or filling it with liquid urathane...
I'm sure it'll help and work for a while... but with a torn or worn core the top material is just gunna get shaken loose eventually.
Also be sure to install the mounts in the proper order... if they go in even slightly crooked the shaking can be pretty rediculous...
I think a LOT of the people who complain about the shakiness of mounts are not properly installed... because mine used to shake like all hell... both when they weren't in right and when the car was idling or running poorly... but when it's in tune and they're in right the vibrations in the cabin are pretty minimal.
Good luck and post the results.
Old Apr 14, 2004 | 03:26 PM
that's true but 10 buck plus some time upgrade should get you through hard time during the swap..
Old Apr 14, 2004 | 04:17 PM
wizzards581's Avatar
Default Re: (Greasemonkey)
i got the driver side insert for GSR. im not using it. its brand new. i only used tranny side and firewall side. let me know if you want mines.i can take pics. its hard to install it though thats y i didnt touch it.
Old Apr 14, 2004 | 04:55 PM
Brewer's Avatar
Default Re: where to buy mount inserts?? (GReddy SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=713941 </TD></TR></TABLE>
That's where I ordered mine from
.BigSexy
Suspension & Brakes
Jul 18, 2006 01:45 PM
DB1_559
Jun 8, 2006 03:52 PM
Tim.
18
Jun 14, 2005 10:54 AM
Brewer
Mar 23, 2004 07:30 PM
94lsboost
Oct 15, 2003 02:49 PM
