Cleaning off Tar, Rubber, and other stuff question
What is the best thing on the market to clean off rubber, tar, bugs, and other stuff? As a result of being on the track nose to tail, it is apparant I have got a lot of rubber marks (rubber coming off the car in front of me) all along the front of my car. Can't see to get it off. Any suggestions?
you should really try to keep a lot of the car waxed so that it becomes VERY simple to take that grime off. BUT the best thing to do before an event is to put Vaseline on the parts that get HEAVILY stained. this way things don't stick on the paint and/or etch your clear coat.
Use Fine rubbing compound to take it out then polish it to make certain that you put the color back in from the abrasives of the compound. after that put some CARNUBA wasx to protect it!
good luck.
good luck.
