--**Billy the Kid's Garage Sale**--LS Block, shift linkages, VSS +more!!
My friend and I are cleaning out the garage and letting go of all the parts we don't need anymore. I only have a couple of references on HT but I have an eBay rating of 23 (100%) positive feedbacks ('Surferbillyboy' if you wish to look it up). Please feel free to PM me with questions about the items I'm selling and I'll be sure to answer them as promtly as I can.
**All items are listed <U>without</U> shipping costs included as shipping will be arranged with serious buyers only**
**All items are OBO- Or Best Offer- so make a decent offer and you probably won't be refused!**
Thanks!
Electronic VSS - Velocity Speed Sensor -was included in a 1st Gen B16a swap purchased from H-Motors but was never used. We needed a cable VSS so this one's up for grabs. $50 (cheap!) PENDING
Shift Linkage - A modified linkage that came in a CRX that had an LS swap. Has been cut and welded to fit. Comes with what you see here including shifter and **** (!) - $75 OBO
Shift Linkage - A full linkage (pic available soon) that is believed to be out of an Integra. Should work with any B-Series but check before you buy - $75 OBO
B18B1 Oil Pump - 60k miles on it. (Sorry no pic) Still worked great when it was removed 2 months ago - $30 OBO
Fast Idle Control Valve - Came off of an LS longblock - in working condition when removed 2 months ago - $20 OBO
B18B1 Shortblock - Had approx 60k miles when removed. Block is complete (minus rods & pistons) but is disassembled. Comes with working Alternator+ belt, water pump, timing belt tensioner, Stage2 clutch installed (not sure how many miles), Crankshaft, and a BRAND NEW LS oil pan+ gasket. The pan alone was close to $100 about 6 months ago - $200 OBO takes it all (Reduced price!!)
B18B1 Head - complete with cams+ gears and intake manifold, though most sensors are removed. Some bolts are missing but comes with 2 LS valve covers (see pics) - $50 OBO SOLD
B18B1 cams - came out of my '97 Ls head, great condition (no pic)- $15 OBO
B16A1 Fuel Rail - no injectors but plugs are still there - $10 OBO
B18B1 Distributor - Was in fine working condition but one of the legs was removed in an attempt to retrofit it (don't ask) - $20 OBO
B16/B17/B18C DOHC Vtec Valve Cover - paint was stripped by previous owner and an attempt was made at polishing it. A few dings in it (see pics) - $20 OBO SOLD!
B16A1 Throttle Body - came with the 1st Gen B16 swap from H-Motors. Includes throttle cable pulley - $20 OBO
(2) '90-'93 Integra halfshafts - fine working condition. You need one of these if you're swapping a B-series into a CRX and using '90-'93 axles - $45 each OBO
'93-'98 VW Jetta No-name front strut bar - has some scratches but was never installed - $10 OBO
Civic Radiator - was in working condition when removed - $20 OBO
Now for the Pictures:
VSS
B-series into CRX modified Shift Linkage
B18B1 Shortblock
B18B1 Head+intake manifold+ extra valve cover
SOLD
B16A1 Fuel Rail
B18B1 Distributor
B16A Throttle Body
90-93 Integra Halfshafts (2)
Thanks for looking!
Modified by Quiks66 at 5:28 AM 4/14/2004
Modified by Quiks66 at 6:03 PM 4/14/2004
Modified by Quiks66 at 3:05 AM 4/18/2004
Modified by Quiks66 at 7:33 PM 4/19/2004
Thanks!
VSS
B18B1 Shortblock
SOLD
B16A1 Fuel Rail
B18B1 Distributor
B16A Throttle Body
Thanks for looking!
Late mornin' BUMP - pretty much ANY reasonable offer will be taken on this stuff. Don't be scared
Bump for a cool dood. I'll be seeing you this weekend. Check your PM and give me a call so i can get your location info.
Just wanted to let you know that that's not a b18b1 distributor. Its out of a b18a(Clear/White harness gives it away) b18b's have a grey harness
Thanks for the heads up on that one. The dizzy is off of a B18a but was being used on a B18b
Mo'nin bump. Price of the block reduced! I need to get this stuff out of my garage as soon as possible, yo!
The B16 throttle body is the OEM 58mm. PM me if you're interested
Also...the valve cover is pending. Let you know if it falls through, but not likely
Payment recieved! Will ship either today or tomorrow (as soon as I find the box I'm shipping it in). Thanks again, and BUMP IT UP, yo!
