I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use?
Old Apr 13, 2004 | 10:35 AM
Solo2Vtec's Avatar
Default I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use?
I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use? Hopefully plug in play?
Old Apr 13, 2004 | 11:04 AM
VTECVillain's Avatar
Default Re: I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use? (Solo2Vtec)
Depending on your state's emissions, the best "stock" ECU would be an OBD1 P72 GSR ECU. With that you will need an OBD2B to OBD1 adapter which you can easily get for less than $100 shipped. The only ECU that would be plug and play with your harness is 00-01 P72 which has an immobilizer built in.
Old Apr 14, 2004 | 01:40 PM
Solo2Vtec's Avatar
Default Re: I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use? (VTECVillain)
Thank You
Old Apr 14, 2004 | 09:32 PM
BLK99VTECR's Avatar
get a USDM P72 though cause i already have the swap that ur about to do and my JDM P72 has a speed cut a 120mph which sucks for highway racing so im in the process right now myself looking to get a new ECU.
94_b18c
Engine Management and Tuning
14
Feb 1, 2013 06:38 PM
xxjokoxx
Jan 26, 2009 05:19 PM
HYPERION-X
Dec 7, 2003 04:52 PM
Stew Pidasso
Feb 20, 2003 01:07 PM
