lsvtec in 99 EK w/ 99 ek wire harness
Old Apr 13, 2004 | 08:33 AM
lsvtec101's Avatar
Default lsvtec in 99 EK w/ 99 ek wire harness
what dizzy do i use and crank angle sensor? ineed one that plugs into the 99 ek harness thnx
Old Apr 15, 2004 | 06:19 PM
92eg-pa's Avatar
Default Re: lsvtec in 99 EK w/ 99 ek wire harness (aemcivic_02917)
i used a dizzy off of a 99 si new from the dealer, with wiring from my 99 ex dizzy
Old Apr 16, 2004 | 09:01 AM
lsvtec101's Avatar
Default Re: lsvtec in 99 EK w/ 99 ek wire harness (99Civb20)
did you rewire the plug or did it plug right in?
Old Apr 16, 2004 | 09:32 AM
92eg-pa's Avatar
i took the harness off the one from the ek, then used that in place of the harness in the 99 si dizzy, then used the rest of the stuff off of the 99 si dizzy as well
Old Apr 16, 2004 | 09:39 AM
showtymers619's Avatar
* B A N N E D *
or you can buy a SI harness from the junkyard hehehe...
Old Apr 16, 2004 | 02:11 PM
92eg-pa's Avatar
Default Re: lsvtec in 99 EK w/ 99 ek wire harness (ShowTymers619)
an si harness and ex harness are different though
Old Apr 16, 2004 | 03:15 PM
lsvtec101's Avatar
all i need to know is what DOHC Vtec Dizzy will fit in my 99 EX dizzy plug. also the crank sensor too
adamrich33
Mar 15, 2009 01:24 PM
StOnErTuNinG
Aug 4, 2006 07:53 AM
jdmfun99
Jun 6, 2004 10:42 PM
