FS: 1991 HONDA CRX SI DRAG CAR CHASSIS SHELL WITH STROKER MOTOR (TX)
For Sale is a 1991 Honda Crx Si Drag Racing Chassis. This chassis is in perfect high quality condition with no dents/dings/rust. The Car has run 11.80’s allmotor with a very conservative motor and 12.20’s on stock LS/Vtec motor. The Chassis weighs 1700 lbs with driver with nothing major cut out of the body. There is much more potential out of this car.
For Sale B18C5 RS Machines Magnum Race Block. All engine Components are BRAND NEW and still in box. There are ZERO miles on the re-sleeved block and its components. This is a brand new set-up.
Vehicle Make and Chassis:
-1991 Honda Crx Si
-Vin# JHMED9365LS000534
Exterior:
-Custom Paint Job Exterior/Interior/Engine Bay
-House of Kolor Silver Base Coat
-House of Kolor Candy Lime Paint
-House of Kolor Clear Coat
-Shaved Gas Cap and Antenna Hole
-MB Products 1-pc Front End With Brackets
-Wings West Side Skirts and Door Caps
-Buddy Club Rear Bumper
-High Quality Scratch Resistant Lexan Windshield, Doors, Quarter panels
-Custom Removable Zeus Lexan Rear Hatch
-Tinted Lexan Sunroof
-STR Rear Defuzer
-Moroso Battery Cut-Off Switch
-Moroso External Battery Jumper Terminals
-Clear Tail Lights
-Autometer Phantom Series Voltmeter
Interior:
-C&T Fab. Full Sheet metal Dash
-C&T Fab. Sheet metal door panels
-C&T Fab. Sheet metal rear quarter panels
-C&T Fab. Sheet metal rear floorboard
-C&T Fab. Roll Cage
-Sparco Racing Seat
-5 Point harness Belt
-Racing Steering Wheel
-Autometer Phantom Series Tach With Shift Light
-Autometer Phantom Series Fuel Pressure
-Autometer Phantom Series Oil Temperature
-Autometer Phantom Series Oil Pressure
-Autometer Phantom Series Stoichmeter
Suspension:
-Tokico 5-Way Adjustable Shocks Front/Back
-Drag Racing Coilovers, Ground Control Perch With Eibach Springs
-Energy Suspension Full Bushings
-Ingall Camber Kit
-Strut Bar
-Skunk2 Extend Wheel Studs Front/Back
Engine:
-B18C5 Type-R Stroker Block (New)
-RS Machines ¾” Deck Plate
-RS Machines Magnum 86mm Iron Ductile Sleeves
-Eagle Specialty Prod. 4340 Steel 95mm Stroke Crank (New In Box)
-Balanced and Blueprinted Crank
-Crower 4340 Steel Custom “Long” Rod (New In Box)
-Arias High Compression Gas Ported Pistons (New In Box)
-Total Seal Piston Rings (New In Box)
-ARP Custom Deck Plate Headstuds (New In Box)
-Cometic 86mm Head Gasket (New In Box)
-ACL Bearings (New In Box)
-New Water Pump
-New Oil Pump
-All New Bolts
Accessories:
-Hasport Billet Motor Mounts
-JAZ 1-Gallon Fuel Cell
The car was built with quality components in mind from the exterior, interior, to the engine. The car has only run 2 events (NHRA and IDRC). The car has won 5 show trophies in 5 shows under Drag Car Class, including 3 1st place trophies. Moving to Florida for graduate school so I can no longer keep the car.
Asking $4,000 or obo. For Chassis
Asking $3,500 or obo. For Short Block
IM or email at tracy@importsource.net for complete details and specs on the car.
Modified by Importsource at 2:04 PM 5/11/2004
Thats a very clean car for sure I would buy it if i didn't alreat have the same damn car
<A HREF="http://www.racingsouthwest.com/forums/index.php?&act=Garage&CODE=12&CID=13
" TARGET="_blank">http://www.racingsouthwest.com...=13
</A>
<A HREF="http://www.racingsouthwest.com/forums/index.php?&act=Garage&CODE=12&CID=13" TARGET="_blank">http://www.racingsouthwest.com...=13
</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysticSpade »</TD></TR><TR><TD CLASS="quote">any motor pics?</TD></TR></TABLE>
willing to sell complete chassis or complete motor by themselves. either or, not going part out smaller components though. make me an offer!!!
years, time to sell
