Question about ordering/replacing shocks/struts
Old Apr 12, 2004 | 11:08 PM
civicmon's Avatar
Default Question about ordering/replacing shocks/struts
This may sound like a stupid question but I've never had to order shocks/struts before, but assuming I were to order this one from NOPI: http://www.nopionline.com/nopi...01996
Is that all I'll need or is there anything else I need to order?
TIA.
Old Apr 13, 2004 | 01:29 AM
carsaregood's Avatar
Default Re: Question about ordering/replacing shocks/struts (civicmon)
you'll need two of those, and two rear ones that will be a different part number. that's all you'll need if all you are doing is replacing the struts.
well, you might need to get an alignment after they're installed, but that's all i can think of right now.
Old Apr 13, 2004 | 10:33 AM
civicmon's Avatar
heh I knew that I needed two of them, but wasn't sure if there were some sort of mounts or whatever I needed to install.
Thanks!
Old Apr 13, 2004 | 01:36 PM
ajjohnsonnc1's Avatar
nope no mounts. if u have stock springs u will need a spring compressor (can be rented from autozone) and a jack, basic hand tools and jack stands.
good luck I changed mine and it took bout 2hrs. Then i did my 2 other friends cars and had it down to bout an hour by the third car
that_boy_sammy
24
Aug 23, 2009 03:16 PM
11:11
Jan 20, 2009 03:20 PM
crxaddikt
Jul 2, 2004 08:15 AM
KoKreation
Oct 23, 2003 08:43 AM
1st-hybrid
10
Sep 24, 2002 06:05 AM
