Pics of Z10 Radius Install
Old Oct 28, 2001 | 12:02 PM
Jason's Avatar
Default Pics of Z10 Radius Install
Well, Asspenny (Craig) and I did an install of these on his car the other night...went pretty smoothly except for a minor incident w/ the center bolt...the bolt that was supplied was too long, it hit the radiator from underneath....enjoy the pics...
[Modified by typer98, 4:06 PM 10/28/2001]
Old Oct 28, 2001 | 12:09 PM
Initial_E's Avatar
Default Re: Pics of Z10 Radius Install (typer98)
They look sweet. Where can I get them? How much are they?
Old Oct 28, 2001 | 12:20 PM
Jason's Avatar
Default Re: Pics of Z10 Radius Install (Initial_E)
here's a link to a post concerning the group buy...it was around $330 for them, regular retail is like 50 bucks more...not too shabby...
here ya go https://honda-tech.com/zerothread?id=73660
Old Oct 28, 2001 | 01:08 PM
fangtl's Avatar
does it work?
Old Oct 28, 2001 | 01:31 PM
Mike K's Avatar
Default Re: Pics of Z10 Radius Install (fangtl)
Installed a set on my friend's 96 EX w/ B18C5 last night.
YES they work. Unfuckingbelieveable. Made a phenommenal difference.
I'm getting two sets. One for the R, one for the CX.
Old Oct 28, 2001 | 01:43 PM
Ricehornet's Avatar
Default Re: Pics of Z10 Radius Install (Mike K)
Damn, those arms look real close to the tire.....no rubbage?
also, do you notice them there if you not pushing the car, like if your not launching.....i'd imagine they have some cornering benfits also....input?
Old Oct 28, 2001 | 01:46 PM
fangtl's Avatar
But that was on a Civic. How about for the ITR?
Old Oct 28, 2001 | 01:50 PM
Rhetoric's Avatar
How long does the average install take? Would there be a problem with scraping when going over speed bumps and such?
Old Oct 28, 2001 | 01:51 PM
Jason's Avatar
Default Re: Pics of Z10 Radius Install (Ricehornet)
very close to the tire...actually, I couldn't fit a finger in between them, that's how close it comes...
as far as it helping, it's not my car, and he's only had it on there for a day, so....
maybe he'll chime in (tomorrow, most likely)
Old Oct 28, 2001 | 03:11 PM
Paisan's Avatar
New User
I just ordered a set for my Si this past Friday. Hopefully, I'll get it by the middle of this week. Can't wait!!
Old Oct 28, 2001 | 03:13 PM
jond's Avatar
Default Re: Pics of Z10 Radius Install (Paisan)
What do they do?
Old Oct 28, 2001 | 03:16 PM
Paisan's Avatar
New User
Default Re: Pics of Z10 Radius Install (jond)
Mainly, they prevent wheel hop when launching at high RPM's. Goto their site, http://www.z10eng.com
Old Oct 28, 2001 | 03:27 PM
MrBite's Avatar
For those who don't want to search through the site, it says the kit "Stops forward/backward movement of the lower control arm, strengthening the lower control arm assembly." For drag and road racing applications.
Old Oct 28, 2001 | 04:00 PM
555R's Avatar
for those who want to know
they do not have any ground clearance probs
unless you are slammed to the ground then maybe
certain wheel/tire combos may rub at full lock
but when are you ever at full lock
it depends on size and offset
it does work on the track and off the track
road racing . it keeps your tires planted and stable
drag it prevents wheel hop
just get a set and you will reap the benefits Ive know of a year ago
try that with the "other" brand
Craig nice setup BTW
and nice black brakes too
as for the long bolt
I have never used one there
just get a shorter one or delete it
Old Oct 28, 2001 | 05:02 PM
R134's Avatar
Does the clearance between the tire and rods change when the car is on jackstands and when it is on the ground? Less than the width of a finger is not much clearance.
Old Oct 28, 2001 | 05:41 PM
Kengs's Avatar
Default Re: Pics of Z10 Radius Install (R134)
Are they like the old "traction bars" for muscle cars?
Old Oct 28, 2001 | 05:58 PM
AssPenny's Avatar
Default Re: Pics of Z10 Radius Install (kengs)
Okay here is the deal on the bars. You must put the center bolt. I ran it 1 day with out the center bolt and the bar was moving atleast a 1/4 to 1/2 and inch. It also made a thud noise when you accelerate and hit the brakes realy hard. I put a shorter bolt in and it elimnated all the noise. 2 days on and there are no marks on the bars from the tires, so I take it they are not rubing.
My only concerin is that the steering wheel is off to one side so we (Jason & I) think that one of the bars is tighter then the other. We just have to play around with the bars a little bit. Right now we have them at 2 turns and I still get a little bit of wheel hop, but that is for like 1 second, then they just spin. Also I'm getting a little noise from the bars moving so make sure you use some grease on the ball joints (we did not so we have to take it apart and put some on). As for it effecting the jack points or anything, everything else is normal. The only thing that is change, is you dont put the splash shield back on. We are going to cut it up a little and see if we can put it back on, but that is not a major issue or anything. Very easy to install and straight foward. I'll keep you all up to date over the next few days on how it feels.
Old Oct 28, 2001 | 06:35 PM
chad's Avatar
Moderator
great another MOD i need to do! more money to spend!
Old Oct 28, 2001 | 07:09 PM
555R's Avatar
Default Re: Pics of Z10 Radius Install (chad)
get a camber caster gauge cos if its off your wheel will be
i get mine adjusted at a local chassis shop
I have access to the scales and all the gauges and stuff
Old Oct 28, 2001 | 07:49 PM
seek167's Avatar
Default Re: Pics of Z10 Radius Install (555R)
will it interfear with sway bars on a ek9
Old Oct 30, 2001 | 07:28 AM
Z10 Motorsports's Avatar
New User
Default Re: Pics of Z10 Radius Install (seek167)
Thank you for all of the great feedback on our products,
For anyone who is having difficulty with installing the radius arms as far as the center bolt that is applied through the radiator support, please email me, this is a problem that we have not seen nor heard about before. You can contact me via email at justin@z10eng.com or feel free to give us a call at 732-922-2309 and ask for justin. Thank you
Old Nov 14, 2001 | 06:48 AM
New User
Default Re: Pics of Z10 Radius Install (Z10 Motorsports)
yes
Old Nov 14, 2001 | 06:52 AM
sackdz's Avatar
That's kind of irritating.
Old Nov 14, 2001 | 06:53 AM
Willard's Avatar
Default Re: Pics of Z10 Radius Install (sackdz)
VERY!
Will
New User
sorry
