Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
97-01 CRV swaybar thickness?
Old Apr 12, 2004 | 08:22 PM
b18c4door's Avatar
Default 97-01 CRV swaybar thickness?
Any honda guru's here know front and rear swaybar thicknesses? I already asked on hondasuv.com...
Apparently, the type-r bar can be used as an upgrade. I would think CRV's would be bigger based on weight and size!
Type-r thickness would be good to know too!
Thanks!
Old Apr 12, 2004 | 08:29 PM
DooD's Avatar
Default Re: 97-01 CRV swaybar thickness? (b18c4door)
the thickness of the rear sway bar is 16 or 17 mm i believe.
I know that it is only 1 or 1 mm thinner than that of the GS-R.
The Cr-V sway bar is upgradable to the GS-R with no serious modification needed. If you use the Type R sway bar (which is much thicker) then you will need custom brackets to hold it in place.
And if i was told correctly, the front sway bar is the same as that as a civic type r. <--- not 100% on that one....but was told from a pretty good source.
Hope that helps.
Old Apr 13, 2004 | 12:30 AM
RangerJoe's Avatar
you can get polyuretheyne mounts made for a new sway bar for pretty cheap. there should be a section in your yellow pages for poly products. call a few places, someone is generally willing to do a 1-off job, esp something small like sway bar brackets.
(you might go to poly either way. they are quieter, and stronger)
Old Apr 13, 2004 | 06:24 PM
b18c4door's Avatar
Default Re: (RangerJoe)
DooD - Thanks! Type-R is the way to go - the 22mm is huge. According to hondautomotiveparts.org , CRV is the same as an 99-00 Civic SI swaybar at a puny 13mm. The type-r will be like whoa
I need to just find a used type-r bar and go from there, ya know? Someone on hondasuv says the type-r can be bolted on with no modifications. I am afraid it will rip out, though.
I wonder if Beaks or BSQ can help come up with a mount kit.
jonesvirs
Suspension & Brakes
16
Dec 8, 2010 09:00 AM
tweek_boii
19
Nov 13, 2009 06:31 AM
dj12oclock
Honda Civic (2006 - 2015)
Mar 19, 2008 12:19 AM
Rick hybrid
Honda Civic (2001 - 2005)
12
Dec 3, 2007 02:48 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
