Really hard for me to go into 1st when rolling at all?
Old Apr 12, 2004 | 07:52 PM
Bay_707's Avatar
Default Really hard for me to go into 1st when rolling at all?
Its really hard for me to go into first gear even when im going like 2 miles per hour. When im completely stopped its fine. I have a b16 tranny and act 3 puck clutch in my 95 gsr. Anyone have any ideas?
Old Apr 12, 2004 | 08:03 PM
Bay_707's Avatar
Default Re: Really hard for me to go into 1st when rolling at all? (707_Eclipse)
I have stalled the car a few times but i dont think it would really do anything like this... i have been told its normal... duno
Old Apr 12, 2004 | 08:05 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 707_Eclipse &raquo;</TD></TR><TR><TD CLASS="quote">Its really hard for me to go into first gear even when im going like 2 miles per hour. When im completely stopped its fine. I have a b16 tranny and act 3 puck clutch in my 95 gsr. Anyone have any ideas?</TD></TR></TABLE>
same thing happens to me..i think its normal, ive heard there is s shift block when your moving , for first gear.
Old Apr 12, 2004 | 08:10 PM
MAV3RiCK478's Avatar
Default Re: Really hard for me to go into 1st when rolling at all? (J337_UNIT)
yes there is a so called shift lock so you don't accidentally shift into 1st at a high rpm.
Old Apr 12, 2004 | 08:16 PM
SweetChin's Avatar
Default Re: Really hard for me to go into 1st when rolling at all? (MAV3RiCK478)
i never heard of a block on first gear... when i try to go into first i always go into second gear first with the clutch down then push it up to first gear... sometime i have to give it a little rev for it to go in
Bay_707's Avatar
i cant be rolling at all though... i mean like 1 or 2 mph and it will be really hard for me to get in
thanks for your quick replys, im sorry this is my first honda/acura.
Old Apr 12, 2004 | 08:28 PM
FlaN.'s Avatar
why would you want to? just curious. I usually shift into second from 2-3 mph anyway
Old Apr 12, 2004 | 08:29 PM
xTravBx's Avatar
Default Re: (FlaN.)
Its suppose to be that way!!! You don't ever want to go back into first if you're moving at all.
Thats just the way it is.
Old Apr 12, 2004 | 08:34 PM
Bay_707's Avatar
Default Re: (FlaN.)
because it sounds weird when you go into second at such low rpms/mph. Is it bad to shift into 1st when you are moving at all? My friend says his car does it with no problem (nscivic on the boards, he has a 94 civic with a b18c1 and a si tranny, basically same setup as me)
Old Apr 12, 2004 | 08:37 PM
FlaN.'s Avatar
Default Re: (707_Eclipse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 707_Eclipse &raquo;</TD></TR><TR><TD CLASS="quote">because it sounds weird when you go into second at such low rpms/mph. Is it bad to shift into 1st when you are moving at all? My friend says his car does it with no problem (nscivic on the boards, he has a 94 civic with a b18c1 and a si tranny, basically same setup as me)</TD></TR></TABLE>
I wouldnt advise it. 1st gear is meant to get the car rolling, and you should shift immediately after the car is rolling unless you're racing of course. at least that is what I think
Old Apr 12, 2004 | 08:39 PM
DC4KiD's Avatar
this is how i see it:
if you're having a tuff time gettin it into 1st while rolling, that means the car is telling you to put it into a higher gear, say 2nd gear.
...dont force it in, you could f*ck things up.
Old Apr 12, 2004 | 08:44 PM
TurboTony's Avatar
Yes, this is true there is a block so you can not go into first gear my car has it too.
Old Apr 12, 2004 | 08:51 PM
SPOONup's Avatar
true .. although while rolling to a corner i can put it in first then take off around the corner ... better than going to 2nd but thats not good for daily driving of course .. like they say dont force it
Old Apr 12, 2004 | 08:53 PM
SPOONup's Avatar
sorry .. also when downshifting through gears to come to a quicker stop NEVER go all the way down to 1st .. stop at 2nd and u can brake from there. I like to rev match through the gears it saves the clutch/tranny ive been told
Old Apr 12, 2004 | 10:12 PM
DIY's Avatar
DIY
Default Re: (showcaseinteg)
very very bad idea to shift into 1st moving.. why would you want to anyways? i cant think of one situation where that would be beneficial...
Old Apr 12, 2004 | 10:22 PM
3.504's Avatar
Default Re: (DIY)
rev match engine speed to rolling speed for that gear, it'll slip right in. the reason it wont go in is because of syncronization process. the syncro's blocker ring is trying to get the 1st speed drive gear to match input shaft speed while this drive gear is moving at output shaft speed, its an easy way for it to work while upshifting, but downshifting is tougher on the syncro. thats why it makes it a crap load easier to help the syncro's job out by rev matching engine speed to rolling speed of car. just give the throttle a little blirp and it'll slip in. this is also the trick when shifting w/o using the clutch, like if you loose hydraulic pressure and you can't dis-engage the clutch... i had to do that once, it sucked.
down shifting is abuse that a manual trans is built from the factory to take, if its grinding gears when you try to do it... dont do it, you'll burn up clutching teath on the drive gears and you'll smoke blocker rings on the syncro, not to mention the clutching teeth and and syncronizer sleeve itself might naw up the shift fork.
and dont shift like a maniac, you dont need to ram the shifter everywhere, even while racing. let the syncro do what its made to do, sometimes it takes a few milliseconds to do this, so allow it to.
thats my .02
Old Apr 12, 2004 | 10:24 PM
3.504's Avatar
Default Re: (DIY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIY &raquo;</TD></TR><TR><TD CLASS="quote">very very bad idea to shift into 1st moving.. why would you want to anyways? i cant think of one situation where that would be beneficial...</TD></TR></TABLE>
beneficial in auto-x... where 4cylinder cars seem to bog if left in 2nd.
Old Apr 12, 2004 | 10:28 PM
hmongboyLS's Avatar
Default Re: (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">rev match engine speed to rolling speed for that gear, it'll slip right in. the reason it wont go in is because of syncronization process. the syncro's blocker ring is trying to get the 1st speed drive gear to match input shaft speed while this drive gear is moving at output shaft speed, its an easy way for it to work while upshifting, but downshifting is tougher on the syncro. thats why it makes it a crap load easier to help the syncro's job out by rev matching engine speed to rolling speed of car. just give the throttle a little blirp and it'll slip in. this is also the trick when shifting w/o using the clutch, like if you loose hydraulic pressure and you can't dis-engage the clutch... i had to do that once, it sucked.
thats my .02</TD></TR></TABLE>
amen to that... yeah if you match rev it, it'll slide in like butter... besides mike, why do you want to go in 1st while rolling?
Old Apr 12, 2004 | 10:36 PM
rough_draft's Avatar
what about downshiftin 2nd to first when racing from like a roll?
Old Apr 12, 2004 | 10:46 PM
Quiks66's Avatar
Default Re: (rough_draft)
Like it was mentioned before, you can simply blip the throttle while giving the shifter a little pressure towards first gear. When the speed of the motor is just right in relation to the speed of the car, you'll feel the "wall" start to give in and it will allow you to slip it into 1st gear. Just don't force it! Feel it out if you have to, but pushing hard against something that doesn't want to budge will make things bad
Old Apr 13, 2004 | 12:45 AM
SweetChin's Avatar
Default Re: (Quiks66)
i kinda downshift to first all the time... like when im comeing up to a red light that i know is going to change green and im only going a few mph, i'll put it in first rather then 2nd... cant stand how slow and long it takes to get the car up to speed in 2nd gear when going that slow... i also do that when i roll through stop signs too... surprised more people dont do that
Old Apr 13, 2004 | 02:06 AM
Smeeg Heed's Avatar
Default Re: (SweetChin)
you're not really supposed to downshift to first, the tranny knows this and will try its hardest to not let you. You should be ok if you've going very very slowly though...
Old Apr 13, 2004 | 05:42 AM
ebelp's Avatar
Default Re: (NS98GSR)
This is normal.
Old Apr 13, 2004 | 07:57 AM
Mrfirefox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by showcaseinteg &raquo;</TD></TR><TR><TD CLASS="quote">true .. although while rolling to a corner i can put it in first then take off around the corner ... better than going to 2nd but thats not good for daily driving of course .. like they say dont force it </TD></TR></TABLE>
take your corners faster, damn 1st gear is slow
pop it in second
Old Apr 13, 2004 | 08:05 AM
luvinmyGSR's Avatar
Default Re: (Mrfirefox)
the same **** happens to me , i tihnk it is some saftey feature so u dont shift into 1st at high rpms.....but i mean its annoying b/c lets say im comming to a stop sign and i kno i have to put it in 1st anyway i have to come to a complete stop b4 i can even put it in first
