Where is the Bypass Solenoid, Two-Way Valve, & PCM?
Old Apr 12, 2004 | 07:48 PM
Red!ine's Avatar
Default Where is the Bypass Solenoid, Two-Way Valve, & PCM?
I got the Code 90 (EVAP Leak).. dealer said to replace the Bypass Solenoid, Two-Way Valve and maybe the PCM if the other two doesn't fix it. Can someone tell me where are these located exactly? (Pics would be helpful) And if anyone has these for sale from parting out your car or something that would be helpful too. Thx
99 Integra BTW
Old Apr 12, 2004 | 09:40 PM
silintegra's Avatar
Default Re: Where is the Bypass Solenoid, Two-Way Valve, & PCM? (kAoTiK)
i think more diagnosis is needed before you replace anything
Old Apr 12, 2004 | 11:23 PM
3.504's Avatar
evap purge selenoid on my DA is located on the firewall. it has vacumm going to it, i'd check the vacumm lines before i'd go off replacing parts. i can't tell you much more than that, havn't got to that class in school yet
Eliot Tapia
May 27, 2019 06:18 PM
RoscoeT
Jul 25, 2015 09:12 PM
LIMERICKAUTO
Acura TL, RL & ZDX
Mar 9, 2013 09:02 AM
vrrodri
May 6, 2011 04:34 PM
Josh10e
Dec 14, 2004 09:52 PM
