B18 OUT OF A 93 LS IN MY 89 CRX SI????
ok there is a guy with a 93 ls that will sell me the engine, tranny and anything else out of it for the engine to work .... so what else am i going to need that the ls wont have to switch into my 89 crx si for it to be up and running???
Mounts... HASport is the best, but some of the cheapos around here use Place and AZ. Then you'll need the wiring harness, and some other stuff, as well as the ECU. Not too bad of a swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker »</TD></TR><TR><TD CLASS="quote">dont forget u have obd0 ,,and 92-93 tegs are obd1....</TD></TR></TABLE>
ooo... good call.
ooo... good call.
You will need the axles and rear tranny bracket. You will have to source out a B-series mount kit, shift linkage (you can use the integra one and have if modified to work in your car), and if you can, you should try and get the front brakes and knuckles too. You will also have to decide if you are going to stay OBD0 or convert to OBD1. I suggest staying OBD0, in which case you will need to find a 90-91 LS ecu, distributor, and you can use your Si injectors. You could try and get away with using your Si distributor and Si computer (not sure on the fitment of the Si dizzy to a LS head) until you get the right parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_GUY_123 »</TD></TR><TR><TD CLASS="quote">i cant use the ecu from the ls??? and i cant use my si harness?? and what other stuffffff?>??</TD></TR></TABLE>
You need the ECU from the LS, and I'm not sure about the wiring harness... I believe that you'll need the one from your car, but I might not be thinking correctly.
You're looking at as much as $500 to put it in there
look ddude all u need is everything manny gives u **** ur harness get the LS harness and ecu that he is gunna give u ....... too many ppl on here are on this bandwagon go ob0 to ob1 to obd 40 while u change it up and go to obd 43 ....... use the LS harness manny will hook u up
Si owWWnnZZZ uRRrrrRRRR aSsSsssssSSSS FF0000000000l !!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi »</TD></TR><TR><TD CLASS="quote">look ddude all u need is everything manny gives u **** ur harness get the LS harness and ecu that he is gunna give u ....... too many ppl on here are on this bandwagon go ob0 to ob1 to obd 40 while u change it up and go to obd 43 ....... use the LS harness manny will hook u up
Si owWWnnZZZ uRRrrrRRRR aSsSsssssSSSS FF0000000000l !!!!!! </TD></TR></TABLE>
English, anyone?
Listen to the other guys
English, anyone?
doesnt make since tho... why would i have to get a ecu from a 90-91 ls??? why wouldnt i jus use everything from the ls im buying it from... everythinggggg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_GUY_123 »</TD></TR><TR><TD CLASS="quote">doesnt make since tho... why would i have to get a ecu from a 90-91 ls??? why wouldnt i jus use everything from the ls im buying it from... everythinggggg</TD></TR></TABLE>
Because the 90-91 LS ECU would be OBD0, the ECU from the 93 LS is OBD1.
Umkay, drugs are bad, umkay....don't do drugs, umkay.....
Get it all.....distributor, ecu, engine, 4 wire O2 sensor. Then all you need is the OBD0-1 conversion harness. You will already have all the electronics. Just need a harness.
http://www.JKOBDConversionHarness.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_GUY_123 »</TD></TR><TR><TD CLASS="quote">PLEASE SAY THIS GUY ISNT SERIOUS....
He is. He did the same thing in one of my threads thats been dead for a week. I already reported him.
</TD></TR></TABLE>He is. He did the same thing in one of my threads thats been dead for a week. I already reported him.
showcivic2001
Jun 25, 2008 09:47 AM
mrtony86
20
May 25, 2006 06:03 AM
pappaj
May 5, 2006 06:13 PM
CRX_GUY_123
Mar 24, 2004 11:33 AM
CRX_GUY_123
Mar 23, 2004 08:22 PM
