nasty motor swap
Old Apr 12, 2004 | 06:12 PM
Slow96IntegraSE's Avatar
Default nasty motor swap
Does anyone know if it is possible to swap an H22 into a 96 integra. If so what will i need besides the motor, trans, and computer, and about what cost am i looking at.
Old Apr 12, 2004 | 06:43 PM
Ryan97GSR's Avatar
yeah you can. i dont know much, but i think you need custom axles, but im not positive
Old Apr 12, 2004 | 06:54 PM
brickonwheels's Avatar
yes, it is possible and a few people on H-T have done it.
Old Apr 12, 2004 | 06:59 PM
SuzukaBlueAP2's Avatar
Default Re: nasty motor swap (Slow96IntegraSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow96IntegraSE &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if it is possible to swap an H22 into a 96 integra. If so what will i need besides the motor, trans, and computer, and about what cost am i looking at.</TD></TR></TABLE>
Why do you consider that a "nasty" swap ?
It's been done before. It's like any other swap as far as parts needed.
Engine, transmission, shift linkage, ECU, axles, wiring harness (and if your car is non-VTEC, then you must do more wiring on your own), you need a mount kit, which HASport makes.
Look at spending atleast $5k for this swap.
What makes you want to do this swap ? What are your future goals for the car ?
Old Apr 12, 2004 | 07:06 PM
Kendall's Avatar
It's a very potent swap, and as mentioned above, shouldn't cost you more than four or five thousand depending upon the cost of the engine. May I suggest you upgrade to a more solid suspension in the front to handle the added weight.
Lamar Thomas
Apr 19, 2016 09:04 PM
slo_hatch
Nov 9, 2007 01:53 AM
tltas0325
Apr 13, 2004 08:21 PM
hondabadboy
Feb 18, 2002 10:12 AM
