Has anyone put a rear disc setup onto a drum trailing arm?
Old Apr 12, 2004 | 05:12 PM
snapcase318's Avatar
Default Has anyone put a rear disc setup onto a drum trailing arm?
Just wondering if anyone has actually changed over the rear disc setup from a 90-93 Integra or 89-91 CRX to a drum trailing arm on the ED"s. I've got everything to change over(from a 93 Integra) but I'd like to just leave my rear trailing arms on and switch over all the componenets due to the trailing arm bushing still being in excellent shape. This site http://home.wideopenwest.com/%7Etschmidt/index.htm seems to lean towards it working but I'd just like to know if anyone has actually done this.
Old Apr 12, 2004 | 05:38 PM
kylefakesi-r's Avatar
Default Re: Has anyone put a rear disc setup onto a drum trailing arm? (snapcase318)
i have not done it but after having disassembled and reassembled both sets of trailing arms that i had i realized after the fat that there would have been alot less heavy lifting and swearing involved had i done it that way.
Old Apr 12, 2004 | 06:57 PM
Jaker's Avatar
I have done it this way twice. Once on an EK, and the 2nd time on my current ED. However, I was not able to do it without removing the trailing arm. The problem is the 4 Torx bolts that hold the hub to the arm. They are most likely (I'll put money on it) seized.
As a result of them being seized, you will most definitely strip the heads. I ended up removing the arm, taking all the drum brake parts off, and taking my grinder with thin cutting disc, and cutting the drum brake hubs off the trailing arm. Lucky for me, the disc brake hubs were already off the trailing arms (thats how I bought them).
If you decide to go ahead with this, the Torx is a size "50".
Old Apr 12, 2004 | 07:07 PM
Default Re: Has anyone put a rear disc setup onto a drum trailing arm? (Jaker)
Jaker-you da man!! thanks so much for the reply. Did you use an impact screwdriver for the torx like you would use on the 4 bolts holding the disc on?
Old Apr 12, 2004 | 07:51 PM
Jaker's Avatar
No I didn't, but I tried damned near everything else.
Old Jun 8, 2004 | 02:16 PM
SloCivicHMM's Avatar
Hate to bring this back up, but..
what rear u have to change out hubs?? cuz my gsr wheel bearings are gone and I have civic drum TA's at home can I swap over the disc stuff to the civic arms and use teh civic bearing or do I have to break down and get GSR bearings...?
Old Jun 8, 2004 | 02:35 PM
6MTV6's Avatar
Default Re: Has anyone put a rear disc setup onto a drum trailing arm? (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">The problem is the 4 Torx bolts that hold the hub to the arm. They are most likely (I'll put money on it) seized.
If you decide to go ahead with this, the Torx is a size "50". </TD></TR></TABLE> The back of the trailing arm is bowl shaped (kind-of)
I just used some PB blaster and let it sit a few days, then used an impact wrench and the Torx size 50. Use a lot of force to hold the inpact to the bolt and they'll pop right out.
Old Jun 9, 2004 | 08:10 AM
Default Re: Has anyone put a rear disc setup onto a drum trailing arm? (Bishop4G)
good idea....I'll be doing this soon...
can I swap over the gsr rear disc......and use my good civic bearings?? or do I have to swap hubs over??
Old Jun 9, 2004 | 09:06 AM
4DRmafia's Avatar
same question but my rear disc is from a crx i think so will that work with an stock civic trailing arms ?
Jr209
Mar 27, 2018 11:55 AM
jacksonww
Oct 5, 2010 05:09 AM
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
blaak-crx
Suspension & Brakes
10
Jun 2, 2008 05:14 PM
ED9man
21
Jun 7, 2006 05:07 PM
