Reverse Indiglo gauges installed! uh oh! No gas gauge!
Old Oct 28, 2001 | 10:13 AM
jdr160's Avatar
Default Reverse Indiglo gauges installed! uh oh! No gas gauge!
I know I know.... I should not have done this, But i did, now its too late! So, all my gauges appear to be working correctly, however, my gas gauge is not moving or calibrated at all. When I removed the needle, the whole shaft came out with it. Any suggestions...?
97 Honda Prelude S
Old Oct 28, 2001 | 12:59 PM
prelude1897's Avatar
Default Re: Reverse Indiglo gauges installed! uh oh! No gas gauge! (jdr160)
You're most likely going to have to take it in and have it fixed. Whenever I read stories like this, it makes me glad I had someone do it for me.
Old Oct 30, 2001 | 06:34 PM
jdr160's Avatar
okay, now all of my gauages work. However, my speedo appears to be off a few mph (approx 5 -10). But my gas gauge when full points to a little over 1/4 tank. Does this help anything? Any way to calibrate and reset everythign to zero, other than disconnecting the battery, i allreasdy did that for about 5 minutes.
Old Oct 30, 2001 | 08:18 PM
BoM's Avatar
BoM
u weren't suppose to remove the needles to install gauges, just overlay them
they were suppose to be ez as pie...plugging in the wires is the hardest part
Old Nov 1, 2001 | 01:05 PM
typesh01's Avatar
New User
Make sure the gauges aren't rubbing up against the needle anywhere and if they are secure them so they don't rub. That happened with mine and once we put a dab of glue down to keep them from rubbing on the needle all was well
97JDMAccord
Apr 21, 2004 07:36 PM
bearboy80
Jun 30, 2003 09:27 PM
Smooth-GSR
Aug 19, 2002 10:22 PM
