Swapping A6 and A11 ecu pinouts for H22 swap.
Old Apr 12, 2004 | 04:11 PM
HAccord96's Avatar
Default Swapping A6 and A11 ecu pinouts for H22 swap.
I have had my H22 swap for almost two years now and I still haven't switched the A6 and A11 wires after the swap. The check engine light comes on after 30 minutes of driving. Yesterday, I decided to swap the two wires, but my obd2 to obd1 conversion harness doesn't have an A11 wire! I was kinda stunned after seeing that.
So my question is, does anyone on H-T know which wire on the original obd2 harness is EGR (A11 on p13 ecu) wire?
I am just going to plug that wire directly into the p13 ecu. Thanks in advance. I hope someone can answer this for me.
PS: I found this: http://importnut.net/h22a_swap.htm and in the chart, A11 for a '93 Prelude is A7 for an OBD2 Accord? Thanks again.
Modified by HAccord96 at 8:46 PM 4/15/2004
Old Apr 12, 2004 | 09:57 PM
HAccord96's Avatar
Default Re: Swapping A6 and A11 ecu pinouts for H22 swap. (HAccord96)
anyone?
Old Apr 14, 2004 | 12:20 AM
HAccord96's Avatar
TTT
Old Apr 14, 2004 | 07:45 AM
JDogg's Avatar
you dont need to worry about it, the wires are right in the jumper.
Old Apr 14, 2004 | 10:58 AM
HAccord96's Avatar
Default Re: Swapping A6 and A11 ecu pinouts for H22 swap. (JDogg)
The problem is, the A11 wire isn't in the jumper for some weird reason. When I ran the H22 off a p72 ecu, I never had a CEL. Anyone else have any ideas? Thanks.
Old Apr 15, 2004 | 03:34 PM
JDogg's Avatar
its not there because a11 is the egr soleniod... p72 dosnt have this and dosnt care
Old Apr 15, 2004 | 05:45 PM
HAccord96's Avatar
I know the P72 doesn't have an A11(egr) solenoid but the thing is, I am running it with a P13 ECU right now...
Old Apr 15, 2004 | 06:13 PM
JDogg's Avatar
then you will have to run the wire from the ecu, the jumper is made for civics/tegs and they dont have egr, so they have no a11
Old Apr 15, 2004 | 07:44 PM
HAccord96's Avatar
Yeah, you are right. Do you know which wire the EGR is on my original OBD2 Accord ecu? I can just hook it up that way also.
Old Apr 15, 2004 | 09:16 PM
JDogg's Avatar
yeah, you can hook it up that way. i do not have my 96 accord book anymore, i sold it when i got rid of the car... sorry
http://www.helminc.com buy the manual.. best 75 bux you will ever spend on your car
Old Apr 16, 2004 | 12:22 AM
HAccord96's Avatar
Thanks for everything, JDogg.
jackiewogn518
Engine Management and Tuning
Feb 27, 2010 10:54 PM
blu_ej
Apr 8, 2008 07:52 PM
91hybridAccord
Jan 17, 2006 03:32 PM
91hybridAccord
Jan 16, 2006 04:44 PM
HAccord96
Apr 14, 2004 12:20 AM
