GM syncromesh where to fill?
Old Apr 12, 2004 | 03:35 PM
Du_Ma's Avatar
Default GM syncromesh where to fill?
can I fill it in where my speed sensor is? or i have to do it like this? do I drain all the fluid out?
Old Apr 12, 2004 | 03:40 PM
jaydub's Avatar
In every car I've ever done, you drain it all and only use the holes they recommend. The reason is so you can fill it just enough where it drips out of the fill hole. One tip: make sure you loosen the fill plug before loosening the drain plug. You don't want to drain it, just to find out that the fill plug is seized.
Old Apr 12, 2004 | 03:45 PM
Du_Ma's Avatar
Default Re: (jaydub)
wat about the place where the speed sensor mount?
newaccordguy2003's Avatar
https://honda-tech.com/zerothread?id=382416
read through that thread, the first post has a great way to fill your transmission.
Old Apr 12, 2004 | 05:32 PM
B2FiNiTY's Avatar
Default Re: GM syncromesh where to fill? (Du_Ma)
You can remove the speed sensor and fill through there. Much easier
demomano
Apr 9, 2008 10:23 PM
luv2boost
Aug 8, 2007 10:06 PM
MiX
Jul 17, 2006 05:37 PM
ajwiant
Mar 4, 2006 08:33 PM
imadigitalgod
Oct 22, 2004 08:33 AM
